AD9267* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017COMPARABLE PARTSREFERENCE MATERIALS View a parametric search of comparable parts. Technical Articles • MS-2210: Designing Power Supplies for High Speed ADC EVALUATION KITS • Understanding Continuous-Time, Discrete-Time Sigma- • AD9267 Evaluation Board Delta ADCs And Nyquist ADCs DOCUMENTATIONDESIGN RESOURCESApplication Notes • AD9267 Material Declaration • AN-1142: Techniques for High Speed ADC PCB Layout • PCN-PDN Information • AN-282: Fundamentals of Sampled Data Systems • Quality And Reliability • AN-283: Sigma-Delta ADCs and DACs • Symbols and Footprints • AN-807: Multicarrier WCDMA Feasibility • AN-808: Multicarrier CDMA2000 Feasibility DISCUSSIONS • AN-812: MicroController-Based Serial Port Interface (SPI) View all AD9267 EngineerZone Discussions. Boot Circuit • AN-835: Understanding High Speed ADC Testing and SAMPLE AND BUY Evaluation Visit the product page to see pricing options. • AN-878: High Speed ADC SPI Control Software • AN-905: Visual Analog Converter Evaluation Tool Version TECHNICAL SUPPORT 1.0 User Manual Submit a technical question or find your regional support Data Sheet number. • AD9267: 10 MHz Bandwidth, 640 MSPS Dual Continuous Time Sigma-Delta Modulator Preliminary Data Sheet DOCUMENT FEEDBACKUser Guides Submit feedback for this data sheet. • UG-093: Evaluation Board User Guide for the Dual, Continuous Time Sigma-Delta Modulator This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Direct Clocking Internal PLL Clock Distribution External PLL Control PLL Autoband Select Power Dissipation and Standby Mode Digital Outputs Digital Output Format Overrange (OR) Condition Timing Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Applications Information Filtering Requirement Memory Map Memory Map Definitions Outline Dimensions Ordering Guide
