Datasheet AD9268 (Analog Devices) - 6
Description16-Bit, 125 MSPS/105 MSPS/80 MSPS, 1.8 V Dual Analog-to-Digital Converter
Pages / Page45 / 6 — AD9268. AD9268BCPZ-80. AD9268BCPZ-105. AD9268BCPZ-125. Parameter. …
AD9268. AD9268BCPZ-80. AD9268BCPZ-105. AD9268BCPZ-125. Parameter. Temperature Min Typ. Max Min Typ. Max Unit
AD9268 AD9268BCPZ-80 AD9268BCPZ-105 AD9268BCPZ-125 Parameter Temperature Min Typ Max Min Typ Max Unit
link to page 6 link to page 6 link to page 6
AD9268 AD9268BCPZ-80 AD9268BCPZ-105 AD9268BCPZ-125 Parameter Temperature Min Typ Max Min Typ Max Min Typ Max Unit
POWER CONSUMPTION DC Input Full 420 450 565 590 750 777 mW Sine Wave Input1 Full 485 608 800 mW (DRVDD = 1.8 V CMOS Output Mode) Sine Wave Input1 Full 582 685 870 mW (DRVDD = 1.8 V LVDS Output Mode) Standby Power3 Full 45 45 45 mW Power-Down Power Full 0.5 2.5 0.5 2.5 0.5 2.5 mW 1 Measured with a low input frequency, full-scale sine wave, with approximately 5 pF loading on each output bit. 2 Input capacitance refers to the effective capacitance between one differential input pin and AGND. 3 Standby power is measured with a dc input and with the CLK pins inactive (set to AVDD or AGND). Rev. A | Page 5 of 44 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS ADC DC SPECIFICATIONS ADC AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Input Common Mode Common-Mode Voltage Servo Dither Differential Input Configurations VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations CHANNEL/CHIP SYNCHRONIZATION POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS Digital Output Enable Function (OEB) TIMING Data Clock Output (DCO) BUILT-IN SELF-TEST (BIST) AND OUTPUT TEST BUILT-IN SELF-TEST (BIST) OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Transfer Register Map Channel-Specific Registers MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS Sync Control (Register 0x100) Bits[7:3]—Reserved Bit 2—Clock Divider Next Sync Only Bit 1—Clock Divider Sync Enable Bit 0—Master Sync Enable APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations LVDS Operation Exposed Paddle Thermal Heat Slug Recommendations VCM RBIAS Reference Decoupling SPI Port OUTLINE DIMENSIONS ORDERING GUIDE
