Datasheet AD7986 (Analog Devices) - 2
Description18-Bit, 2 MSPS PulSAR 15 mW ADC in QFN
Pages / Page29 / 2 — AD7986* PRODUCT PAGE QUICK LINKS Last Content Update: 04/14/2017. …
RevisionD
File Format / SizePDF / 629 Kb
AD7986* PRODUCT PAGE QUICK LINKS Last Content Update: 04/14/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD7986* PRODUCT PAGE QUICK LINKS Last Content Update: 04/14/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• SAR ADC & Driver Quick-Match Guide
EVALUATION KITS Solutions Bulletins & Brochures
• AD7986 Evaluation Board • Analog-to-Digital Converter and Drivers ICs Solutions Bulletin, Volume 10, Issue 2
DOCUMENTATION
• Test & Instrumentation Solutions Bulletin, Volume 10,
Application Notes
Issue 3 • AN-742: Frequency Domain Response of Switched-
Technical Articles
Capacitor ADCs • MS-1779: Nine Often Overlooked ADC Specifications • AN-931: Understanding PulSAR ADC Support Circuitry • MS-2210: Designing Power Supplies for High Speed ADC • AN-932: Power Supply Sequencing
Tutorials Data Sheet
• MT-001: Taking the Mystery out of the Infamous Formula, • AD7986: 18-Bit, 2 MSPS PulSAR 15 mW ADC in LFCSP "SNR=6.02N + 1.76dB", and Why You Should Care (QFN) Data Sheet • MT-002: What the Nyquist Criterion Means to Your
Technical Books
Sampled Data System Design • The Data Conversion Handbook, 2005 • MT-031: Grounding Data Converters and Solving the Mystery of "AGND" and "DGND"
User Guides
• MT-074: Differential Drivers for Precision ADCs • UG-727: Evaluating the AD7944/AD7985/AD7986 14-/16-/ 18-Bit, PulSAR ADCs
DESIGN RESOURCES
• AD7986 Material Declaration • PCN-PDN Information • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all AD7986 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION CONVERSION MODES OF OPERATION Transfer Functions TYPICAL CONNECTION DIAGRAM ANALOG INPUTS DRIVER AMPLIFIER CHOICE VOLTAGE REFERENCE INPUT Internal Reference, REF = 4.096V (PDREF = Low) External 1.2 V Reference and Internal Buffer (PDREF = High) External Reference (PDREF = High, REFIN = Low) Reference Decoupling POWER SUPPLY DIGITAL INTERFACE DATA READING OPTIONS Reading During Conversion, Fast Hosts (Turbo or Normal Mode) Split-Reading, Any Speed Host (Turbo or Normal Mode) Reading During Acquisition, Any Speed Hosts (Turbo or Normal Mode) /CS MODE, 3-WIRE WITHOUT BUSY INDICATOR /CS MODE, 3-WIRE WITH BUSY INDICATOR /CS MODE, 4-WIRE WITHOUT BUSY INDICATOR /CS MODE, 4-WIRE WITH BUSY INDICATOR CHAIN MODE WITHOUT BUSY INDICATOR CHAIN MODE WITH BUSY INDICATOR APPLICATION HINTS LAYOUT EVALUATING THE PERFORMANCE OF THE AD7986 OUTLINE DIMENSIONS ORDERING GUIDE
