Datasheet AD7781 (Analog Devices) - 2
Description20-Bit, Pin-Programmable, Ultralow Power Sigma-Delta ADC
Pages / Page17 / 2 — AD7781* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 329 Kb
AD7781* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD7781* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Solutions Bulletins & Brochures
• Test & Instrumentation Solutions Bulletin, Volume 10,
EVALUATION KITS
Issue 3 • AD7781 Evaluation Board
Technical Articles
• High-resolution ADCs — an overview
DOCUMENTATION
• MS-2210: Designing Power Supplies for High Speed ADC
Application Notes
• AN-968: Current Sources: Options and Circuits
DESIGN RESOURCES Data Sheet
• AD7781 Material Declaration • AD7781: 20-Bit, Pin-Programmable, Low Power Sigma- • PCN-PDN Information Delta ADC Data Sheet • Quality And Reliability
User Guides
• Symbols and Footprints • UG-079: Evaluation Board for the AD7781 20-Bit, Pin- Programmable, Low Power, Sigma-Delta ADC
DISCUSSIONS
View all AD7781 EngineerZone Discussions.
SOFTWARE AND SYSTEMS REQUIREMENTS
• AD7780 IIO Low Power Sigma-Delta ADC Linux Driver
SAMPLE AND BUY
• AD7781 Evaluation Board Software Visit the product page to see pricing options. • AD7781 Evaluation Software Labview Source Code
TECHNICAL SUPPORT TOOLS AND SIMULATIONS
Submit a technical question or find your regional support • Sigma-Delta ADC Tutorial number.
REFERENCE DESIGNS DOCUMENT FEEDBACK
• CN0108 Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING CHARACTERISTICS Circuit and Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTPUT NOISE AND RESOLUTION THEORY OF OPERATION FILTER, DATA RATE, AND SETTLING TIME GAIN POWER-DOWN/RESET (PDRST) ANALOG INPUT CHANNEL BIPOLAR CONFIGURATION DATA OUTPUT CODING REFERENCE BRIDGE POWER-DOWN SWITCH DIGITAL INTERFACE APPLICATIONS INFORMATION WEIGH SCALES AD7781 PERFORMANCE IN A WEIGH SCALE SYSTEM EMI RECOMMENDATIONS GROUNDING AND LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE
