Datasheet AD7356 (Analog Devices) - 2
DescriptionDifferential Input, Dual, Simultaneous Sampling, 5 MSPS, 12-Bit, SAR ADC
Pages / Page21 / 2 — AD7356* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 615 Kb
AD7356* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD7356* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD7356 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD7356 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all AD7356 EngineerZone Discussions. • AD7356: Differential Input, Dual, Simultaneous Sampling, 5 MSPS, 12-Bit, SAR ADC Data Sheet
SAMPLE AND BUY
Visit the product page to see pricing options.
SOFTWARE AND SYSTEMS REQUIREMENTS
• AD7352/AD7356/AD7357 Evaluation Software
TECHNICAL SUPPORT
Submit a technical question or find your regional support
REFERENCE DESIGNS
number. • CN0041
DOCUMENT FEEDBACK REFERENCE MATERIALS
Submit feedback for this data sheet.
Solutions Bulletins & Brochures
• Analog-to-Digital Converter and Drivers ICs Solutions Bulletin, Volume 10, Issue 2
Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION ANALOG INPUT STRUCTURE ANALOG INPUTS DRIVING DIFFERENTIAL INPUTS Differential Amplifier Op Amp Pair VOLTAGE REFERENCE ADC TRANSFER FUNCTION MODES OF OPERATION NORMAL MODE PARTIAL POWER-DOWN MODE FULL POWER-DOWN MODE POWER-UP TIMES POWER vs. THROUGHPUT RATE SERIAL INTERFACE APPLICATION HINTS GROUNDING AND LAYOUT EVALUATING THE AD7356 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
