Datasheet AD7190 (Analog Devices) - 4
Description4.8 kHz Ultralow Noise 24-Bit Sigma-Delta ADC with PGA
Pages / Page41 / 4 — Data Sheet. AD7190. SPECIFICATIONS. Table 1. Parameter. AD7190B. Unit. …
RevisionC
File Format / SizePDF / 689 Kb
Data Sheet. AD7190. SPECIFICATIONS. Table 1. Parameter. AD7190B. Unit. Test Conditions/Comments1
Data Sheet AD7190 SPECIFICATIONS Table 1 Parameter AD7190B Unit Test Conditions/Comments1
link to page 16 link to page 16 link to page 16 link to page 16 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7
AVDD = 4.75 V to 5.25 V, DVDD = 2.7 V to 5.25 V, AGND = DGND = 0 V, REFINx(+) = AVDD , REFINx(−) = AGND, MCLK = 4.92 MHz, TA = TMIN to TMAX, unless otherwise noted.
Table 1. Parameter AD7190B Unit Test Conditions/Comments1
ADC Output Data Rate 4.7 to 4800 Hz nom Chop disabled. 1.17 to 1200 Hz nom Chop enabled, sinc4 filter. 1.56 to 1600 Hz nom Chop enabled, sinc3 filter. No Missing Codes2 24 Bits min FS > 1, sinc4 filter3. 24 Bits min FS > 4, sinc3 filter3. Resolution See the RMS Noise and Resolution section RMS Noise and Output Data Rates See the RMS Noise and Resolution section Integral Nonlinearity B Grade ±5 ppm of FSR max ±1 ppm typical, gain = 1. ±15 ppm of FSR max ±5 ppm typical, gain > 1. WB Grade ±7 ppm of FSR max ±1 ppm typical, gain = 1. ±30 ppm of FSR max ±5 ppm typical, gain > 1. Offset Error4, 5 ±75/gain μV typ Chop disabled. ±0.5 μV typ Chop enabled. Offset Error Drift vs. Temperature5 ±100/gain nV/°C typ Gain = 1 to 16. chop disabled. ±5 nV/°C typ Gain = 32 to 128. chop disabled. ±5 nV/°C typ Chop enabled. Offset Error Drift vs. Time 25 nV/1000 hours typ Gain ≥ 32. Gain Error4 B Grade ±0.005 % max ±0.001 % typical, gain = 1, TA = 25°C, AVDD = 5 V6. WB Grade ±0.0075 % max ±0.001 % typical, gain = 1, TA = 25°C, AVDD = 5 V6. ±0.0075 % typ Gain > 1, post internal full-scale calibration. Gain Drift vs. Temperature ±1 ppm/°C typ Gain Drift vs. Time 10 ppm/1000 hours typ Gain = 1. Power Supply Rejection 95 dB typ Gain = 1, VIN = 1 V. B Grade 100 dB min Gain > 1, VIN = 1 V/gain. 110 dB typical. WB Grade 95 dB min Gain > 1, VIN = 1 V/gain. 110 dB typical. Common-Mode Rejection @ DC 100 dB min Gain = 1, VIN = 1 V2. 110 dB min Gain > 1, VIN = 1 V/gain. @ 50 Hz, 60 Hz2 120 dB min 10 Hz output data rate, 50 ± 1 Hz, 60 ± 1 Hz. @ 50 Hz, 60 Hz2 120 dB min 50 ± 1 Hz (50 Hz output data rate), 60 ± 1 Hz (60 Hz output data rate). Normal Mode Rejection2 Sinc4 Filter Internal Clock @ 50 Hz, 60 Hz 100 dB min 10 Hz output data rate, 50 ± 1 Hz, 60 ± 1 Hz. 74 dB min 50 Hz output data rate, REJ607 = 1, 50 ± 1 Hz, 60 ± 1 Hz. @ 50 Hz 96 dB min 50 Hz output data rate, 50 ± 1 Hz. @ 60 Hz 97 dB min 60 Hz output data rate, 60 ± 1 Hz. Rev. C | Page 3 of 40 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Characteristics Circuit and Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics RMS Noise and Resolution Sinc4 Chop Disabled Sinc3 Chop Disabled Sinc4 Chop Enabled Sinc3 Chop Enabled On-Chip Registers Communications Register Status Register Mode Register Configuration Register Data Register ID Register GPOCON Register Offset Register Full-Scale Register ADC Circuit Information Overview Filter, Output Data Rate, Settling Time Chop Disabled Chop Enabled 50 Hz/60 Hz Rejection Zero Latency Channel Sequencer Digital Interface Single Conversion Mode Continuous Conversion Mode Continuous Read Circuit Description Analog Input Channel PGA Bipolar/Unipolar Configuration Data Output Coding Clock Burnout Currents Reference Reference Detect Reset System Synchronization Temperature Sensor Bridge Power-Down Switch Logic Outputs Enable Parity Calibration Grounding and Layout Applications Information Weigh Scales Outline Dimensions Ordering Guide Automotive Products
