link to page 24 link to page 11 link to page 23 link to page 23 link to page 23 AD7682/AD7689Data SheetPIN CONFIGURATIONS AND FUNCTION DESCRIPTIONSDDDDVNCN1INCN0IN3VIN2IN1IN0I20191817162019181716VDD 115 VIOVDD 115 VIOREF 214 SDOAD7682REF 214 SDOAD7689REFIN 3TOP VIEW13 SCKREFIN 3TOP VIEW13 SCKGND 4(Not to Scale)12 DINGND 4(Not to Scale)12 DINGND 511 CNVGND 511 CNV678967891010MMNCN2INCN3IN4N5IIN6IN7ICOCONOTESNOTES1. NC = NO CONNECT.1. THE EXPOSED PAD IS NOT CONNECTED2. THE EXPOSED PAD IS NOT CONNECTEDINTERNALLY. FOR INCREASEDINTERNALLY. FOR INCREASEDRELIABILITY OF THE SOLDER JOINTS, ITRELIABILITY OF THE SOLDER JOINTS, ITIS RECOMMENDED THAT THE PAD BE 005 IS RECOMMENDED THAT THE PAD BESOLDERED TO THE SYSTEM 004 SOLDERED TO THE SYSTEMGROUND PLANE. 07353- GROUND PLANE. 07353- Figure 4. AD7682 LFCSP Pin Configuration Figure 5. AD7689 LFCSP Pin Configuration Table 7. AD7682 LFCSP and AD7689 LFCSP Pin Function DescriptionsAD7682AD7689LFCSPLFCSPPin No. MnemonicMnemonicType1Description 1, 20 VDD VDD P Power Supply. Nominally 2.5 V to 5.5 V when using an external reference and decoupled with 10 μF and 100 nF capacitors. When using the internal reference for a 2.5 V output, the minimum must be 3.0 V. When using the internal reference for 4.096 V output, the minimum must be 4.6 V. 2 REF REF AI/O Reference Input/Output. See the Voltage Reference Output/Input section. When the internal reference is enabled, this pin produces a selectable system reference of 2.5 V or 4.096 V. When the internal reference is disabled and the buffer is enabled, REF produces a buffered version of the voltage present on the REFIN pin (VDD − 0.5 V, maximum), which is useful when using low cost, low power references. For improved drift performance, connect a precision reference to REF (0.5 V to VDD). For any reference method, this pin needs decoupling with an external 10 μF capacitor connected as close to REF as possible. See the Reference Decoupling section. 3 REFIN REFIN AI/O Internal Reference Output/Reference Buffer Input. See the Voltage Reference Output/Input section. When using the internal reference, the internal unbuffered reference voltage is present and requires decoupling with a 0.1 μF capacitor. When using the internal reference buffer, apply a source between 0.5 V and (VDD − 0.5 V) that is buffered to the REF pin, as described in the REF pin description. 4, 5 GND GND P Power Supply Ground. 6 NC IN4 AI No Connection (AD7682). Analog Input Channel 4 (AD7689). 7 IN2 IN5 AI Analog Input Channel 2 (AD7682). Analog Input Channel 5 (AD7689). 8 NC IN6 AI No Connection (AD7682). Analog Input Channel 6 (AD7689). 9 IN3 IN7 AI Analog Input Channel 3 (AD7682). Analog Input Channel 7 (AD7689). 10 COM COM AI Common Channel Input. All input channels, IN[7:0], can be referenced to a common- mode point of 0 V or VREF/2 V. 11 CNV CNV DI Conversion Input. On the rising edge, CNV initiates the conversion. During conversion, if CNV is held low, the busy indictor is enabled. 12 DIN DIN DI Data Input. Use this input for writing to the 14-bit configuration register. The configuration register can be written to during and after conversion. 13 SCK SCK DI Serial Data Clock Input. This input is used to clock out the data on SDO and clock in data on DIN in an MSB first fashion. Rev. H | Page 10 of 35 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Overview Converter Operation Transfer Functions Typical Connection Diagrams Unipolar or Bipolar Bipolar Single Supply Analog Inputs Input Structure Selectable Low-Pass Filter Input Configurations Sequencer Source Resistance Driver Amplifier Choice Voltage Reference Output/Input Internal Reference/Temperature Sensor External Reference and Internal Buffer External Reference Reference Decoupling Power Supply Supplying the ADC from the Reference Digital Interface Reading/Writing During Conversion, Fast Hosts Reading/Writing After Conversion, Any Speed Hosts Reading/Writing Spanning Conversion, Any Speed Host Configuration Register, CFG General Timing Without a Busy Indicator General Timing with a Busy Indicator Channel Sequencer Examples Read/Write Spanning Conversion Without a Busy Indicator Read/Write Spanning Conversion with a Busy Indicator Applications Information Layout Evaluating the AD7682/AD7689 Performance Outline Dimensions Ordering Guide
