Datasheet AD9601 (Analog Devices) - 2
Description10-Bit, 200 MSPS/250 MSPS 1.8 V Analog-to-Digital Converter
Pages / Page33 / 2 — AD9601* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 989 Kb
AD9601* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9601* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • AD9601 IBIS Models
EVALUATION KITS REFERENCE MATERIALS
• AD9601 Evaluation Board
Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
DOCUMENTATION Application Notes DESIGN RESOURCES
• AN-1142: Techniques for High Speed ADC PCB Layout • AD9601 Material Declaration • AN-282: Fundamentals of Sampled Data Systems • PCN-PDN Information • AN-501: Aperture Uncertainty and ADC System • Quality And Reliability Performance • Symbols and Footprints • AN-586: LVDS Outputs for High Speed A/D Converters • AN-715: A First Approach to IBIS Models: What They Are
DISCUSSIONS
and How They Are Generated View all AD9601 EngineerZone Discussions. • AN-737: How ADIsimADC Models an ADC • AN-741: Little Known Characteristics of Phase Noise
SAMPLE AND BUY
• AN-742: Frequency Domain Response of Switched- Visit the product page to see pricing options. Capacitor ADCs • AN-756: Sampled Systems and the Effects of Clock Phase
TECHNICAL SUPPORT
Noise and Jitter Submit a technical question or find your regional support • AN-807: Multicarrier WCDMA Feasibility number. • AN-808: Multicarrier CDMA2000 Feasibility • AN-812: MicroController-Based Serial Port Interface (SPI)
DOCUMENT FEEDBACK
Boot Circuit Submit feedback for this data sheet. • AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs • AN-835: Understanding High Speed ADC Testing and Evaluation • AN-878: High Speed ADC SPI Control Software • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual
Data Sheet
• AD9601: 10-Bit, 200 MSPS/250 MSPS 1.8 V Analog-to- Digital Converter Data Sheet
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT AND VOLTAGE REFERENCE Differential Input Configurations CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS Digital Outputs and Timing Out-of-Range TIMING—SINGLE PORT MODE TIMING—INTERLEAVED MODE fS/2 Spurious LAYOUT CONSIDERATIONS POWER AND GROUND RECOMMENDATIONS Exposed Paddle Thermal Heat Slug Recommendations CML RBIAS AD9601 CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
