Datasheet AD9254 (Analog Devices) - 2
Description14-Bit, 150 MSPS, 1.8 V Analog-to-Digital Converter
Pages / Page41 / 2 — AD9254* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
AD9254* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9254* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • AD9254 IBIS Models
EVALUATION KITS REFERENCE MATERIALS
• AD9254 Evaluation Board
Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
DOCUMENTATION Tutorials Application Notes
• MT-230: Noise Considerations in High Speed Converter • AN-1142: Techniques for High Speed ADC PCB Layout Signal Chains • AN-282: Fundamentals of Sampled Data Systems • AN-501: Aperture Uncertainty and ADC System
DESIGN RESOURCES
Performance • AD9254 Material Declaration • AN-715: A First Approach to IBIS Models: What They Are • PCN-PDN Information and How They Are Generated • Quality And Reliability • AN-737: How ADIsimADC Models an ADC • Symbols and Footprints • AN-741: Little Known Characteristics of Phase Noise • AN-742: Frequency Domain Response of Switched-
DISCUSSIONS
Capacitor ADCs View all AD9254 EngineerZone Discussions. • AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter
SAMPLE AND BUY
• AN-807: Multicarrier WCDMA Feasibility Visit the product page to see pricing options. • AN-808: Multicarrier CDMA2000 Feasibility • AN-812: MicroController-Based Serial Port Interface (SPI)
TECHNICAL SUPPORT
Boot Circuit Submit a technical question or find your regional support • AN-827: A Resonant Approach to Interfacing Amplifiers to number. Switched-Capacitor ADCs • AN-835: Understanding High Speed ADC Testing and
DOCUMENT FEEDBACK
Evaluation • AN-851: A WiMax Double Downconversion IF Sampling Submit feedback for this data sheet. Receiver Design • AN-877: Interfacing to High Speed ADCs via SPI • AN-878: High Speed ADC SPI Control Software • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual
Data Sheet
• AD9254: 14-Bit, 150 MSPS, 1.8 V Analog-to-Digital Converter Data Sheet
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS DIFFERENTIAL INPUT CONFIGURATIONS VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS JITTER CONSIDERATIONS POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS TIMING SERIAL PORT INTERFACE (SPI) MEMORY MAP READING THE MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER TABLE LAYOUT CONSIDERATIONS POWER AND GROUND RECOMMENDATIONS CML RBIAS REFERENCE DECOUPLING EVALUATION BOARD POWER SUPPLIES INPUT SIGNALS OUTPUT SIGNALS DEFAULT OPERATION AND JUMPER SELECTION SETTINGS ALTERNATIVE CLOCK CONFIGURATIONS ALTERNATIVE ANALOG INPUT DRIVE CONFIGURATION SCHEMATICS EVALUATION BOARD LAYOUT BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
