link to page 10 Data SheetAD9252ABSOLUTE MAXIMUM RATINGSTHERMAL IMPEDANCETable 5.WithTable 6.ParameterRespect ToRatingAir Flow Velocity (m/s)θ 1JAθJBθJCUnit ELECTRICAL 0.0 17.7 °C/W AVDD AGND −0.3 V to +2.0 V 1.0 15.5 8.7 0.6 °C/W DRVDD DRGND −0.3 V to +2.0 V 2.5 13.9 °C/W AGND DRGND −0.3 V to +0.3 V AVDD DRVDD −2.0 V to +2.0 V 1 θJA for a 4-layer PCB with solid ground plane (simulated). Exposed pad soldered to PCB. Digital Outputs DRGND −0.3 V to +2.0 V (D + x, D − x, DCO+, DCO−, FCO+, FCO−) ESD CAUTION CLK+, CLK− AGND −0.3 V to +3.9 V VIN + x, VIN − x AGND −0.3 V to +2.0 V SDIO/ODM AGND −0.3 V to +2.0 V PDWN, SCLK/DTP, CSB AGND −0.3 V to +3.9 V REFT, REFB, RBIAS AGND −0.3 V to +2.0 V VREF, SENSE AGND −0.3 V to +2.0 V ENVIRONMENTAL Operating Temperature −40°C to +85°C Range (Ambient) Storage Temperature −65°C to +150°C Range (Ambient) Maximum Junction 150°C Temperature Lead Temperature 300°C (Soldering, 10 sec) Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. E | Page 9 of 52 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/ODM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Applications Information Design Guidelines Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Evaluation Board Power Supplies Input Signals Output Signals Default Operation and Jumper Selection Settings Alternative Analog Input Drive Configuration Outline Dimensions Ordering Guide
