Datasheet AD9222 (Analog Devices) - 2
DescriptionOctal, 12-Bit, 40/50/65 MSPS Serial LVDS 1.8 V A/D Converter
Pages / Page61 / 2 — AD9222* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
File Format / SizePDF / 2.6 Mb
AD9222* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9222* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9222 IBIS Models
EVALUATION KITS
• AD9222 Evaluation Board
REFERENCE MATERIALS Technical Articles DOCUMENTATION
• MS-2210: Designing Power Supplies for High Speed ADC
Application Notes
• AN-1142: Techniques for High Speed ADC PCB Layout
DESIGN RESOURCES
• AN-282: Fundamentals of Sampled Data Systems • AD9222 Material Declaration • AN-345: Grounding for Low-and-High-Frequency Circuits • PCN-PDN Information • AN-501: Aperture Uncertainty and ADC System • Quality And Reliability Performance • Symbols and Footprints • AN-715: A First Approach to IBIS Models: What They Are and How They Are Generated
DISCUSSIONS
• AN-737: How ADIsimADC Models an ADC View all AD9222 EngineerZone Discussions. • AN-741: Little Known Characteristics of Phase Noise • AN-742: Frequency Domain Response of Switched-
SAMPLE AND BUY
Capacitor ADCs Visit the product page to see pricing options. • AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter
TECHNICAL SUPPORT
• AN-812: MicroController-Based Serial Port Interface (SPI) Boot Circuit Submit a technical question or find your regional support number. • AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs
DOCUMENT FEEDBACK
• AN-835: Understanding High Speed ADC Testing and Evaluation Submit feedback for this data sheet. • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual • AN-935: Designing an ADC Transformer-Coupled Front End
Data Sheet
• AD9222: Octal, 12-Bit, 40/50/65 MSPS Serial LVDS 1.8 V A/ D Converter Data Sheet
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/ODM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Evaluation Board Power Supplies Input Signals Output Signals Default Operation and Jumper Selection Settings Alternative Analog Input Drive Configuration Outline Dimensions Ordering Guide
