Datasheet AD7951 (Analog Devices) - 4
Description14-Bit, 1 MSPS, Unipolar/Bipolar Programmable Input PulSAR® ADC
Pages / Page33 / 4 — Data Sheet. AD7951. SPECIFICATIONS. Table 2. Parameter. …
File Format / SizePDF / 773 Kb
Data Sheet. AD7951. SPECIFICATIONS. Table 2. Parameter. Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD7951 SPECIFICATIONS Table 2 Parameter Conditions/Comments Min Typ Max Unit
link to page 21 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5
AVDD = DVDD = 5 V; OVDD = 2.7 V to 5.5 V; VCC = 15 V; VEE = −15 V; VREF = 5 V; all specifications TMIN to TMAX, unless otherwise noted.
Table 2. Parameter Conditions/Comments Min Typ Max Unit
RESOLUTION 14 Bits ANALOG INPUT Voltage Range, VIN VIN+ − VIN− = 0 V to 5 V −0.1 +5.1 V VIN+ − VIN− = 0 V to 10 V −0.1 +10.1 V VIN+ − VIN− = ±5 V −5.1 +5.1 V VIN+ − VIN− = ±10 V −10.1 +10.1 V VIN− to AGND −0.1 +0.1 V Analog Input CMRR fIN = 100 kHz 75 dB Input Current VIN = ±5 V, ±10 V @ 1 MSPS 3001 µA Input Impedance See the Analog Inputs section THROUGHPUT SPEED Complete Cycle In warp mode 1 μs Throughput Rate In warp mode 1 1 MSPS Time Between Conversions In warp mode 1 ms Complete Cycle In normal mode 1.25 μs Throughput Rate In normal mode 0 800 kSPS Complete Cycle In impulse mode 1.49 μs Throughput Rate In impulse mode 0 670 kSPS DC ACCURACY Integral Linearity Error2 −1 ±0.3 +1 LSB3 No Missing Codes2 14 Bits Differential Linearity Error2 −1 +1 LSB Transition Noise 0.55 LSB Zero Error (Unipolar or Bipolar) −15 +15 LSB Zero Error Temperature Drift ±1 ppm/°C Full-Scale Error (Unipolar or Bipolar) −20 +20 LSB Full-Scale Error Temperature Drift ±1 ppm/°C Power Supply Sensitivity AVDD = 5 V ± 5% ±0.8 LSB AC ACCURACY Dynamic Range fIN = 2 kHz, −60 dB 84.5 85.5 dB4 Signal-to-Noise Ratio fIN = 2 kHz 84.5 85.5 dB fIN = 20 kHz 85.5 dB Signal-to-(Noise + Distortion) (SINAD) fIN = 2 kHz 83 85.4 dB Total Harmonic Distortion fIN = 2 kHz −105 dB Spurious-Free Dynamic Range fIN = 2 kHz 102 dB –3 dB Input Bandwidth VIN = 0 V to 5 V 45 MHz Aperture Delay 2 ns Aperture Jitter 5 ps rms Transient Response Full-scale step 500 ns INTERNAL REFERENCE PDREF = PDBUF = low Output Voltage REF @ 25°C 4.965 5.000 5.035 V Temperature Drift –40°C to +85°C ±3 ppm/°C Line Regulation AVDD = 5 V ± 5% ±15 ppm/V Long-Term Drift 1000 hours 50 ppm Turn-On Settling Time CREF = 22 µF 10 ms Rev. B | Page 3 of 32 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION OVERVIEW CONVERTER OPERATION MODES OF OPERATION Normal Mode Impulse Mode TRANSFER FUNCTIONS TYPICAL CONNECTION DIAGRAM ANALOG INPUTS Input Range Selection Input Structure VOLTAGE REFERENCE INPUT/OUTPUT Internal Reference (REF = 5 V) (PDREF = Low, PDBUF = Low) External 2.5 V Reference and Internal Buffer (REF = 5 V) (PDREF = High, PDBUF = Low) External 5 V Reference (PDREF = High, PDBUF = High) Reference Decoupling Temperature Sensor POWER SUPPLIES Core Supplies High Voltage Supplies Digital Output Supply Power Sequencing Power Dissipation vs. Throughput Power Down CONVERSION CONTROL INTERFACES DIGITAL INTERFACE RESET PARALLEL INTERFACE Master Parallel Interface Slave Parallel Interface 8-Bit Interface (Master or Slave) SERIAL INTERFACE Data Interface Serial Configuration Interface MASTER SERIAL INTERFACE Internal Clock (SER/PAR = High, EXT/INT = Low) Read During Convert (RDC = High) Read After Convert (RDC = Low, DIVSCLK[1:0] = [0 to 3]) SLAVE SERIAL INTERFACE External Clock (SER/PAR = High, EXT/INT = High) External Discontinuous Clock Data Read After Conversion Daisy-Chain Feature External Clock Data Read During Previous Conversion External Clock Data Read After/During Conversion HARDWARE CONFIGURATION SOFTWARE CONFIGURATION MICROPROCESSOR INTERFACING SPI Interface APPLICATION INFORMATION LAYOUT GUIDELINES OUTLINE DIMENSIONS ORDERING GUIDE
