Datasheet AD7610 (Analog Devices) - 4
Description16-Bit, 250 kSPS, Unipolar/Bipolar Programmable Input PulSAR ADC
Pages / Page33 / 4 — Data Sheet. AD7610. SPECIFICATIONS. Table 2. Parameter. …
RevisionA
File Format / SizePDF / 694 Kb
Data Sheet. AD7610. SPECIFICATIONS. Table 2. Parameter. Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD7610 SPECIFICATIONS Table 2 Parameter Conditions/Comments Min Typ Max Unit
link to page 20 link to page 6 link to page 6 link to page 5 link to page 5 link to page 5 link to page 5
AVDD = DVDD = 5 V; OVDD = 2.7 V to 5.5 V; VCC = 15 V; VEE = −15 V; VREF = 5 V; all specifications TMIN to TMAX, unless otherwise noted.
Table 2. Parameter Conditions/Comments Min Typ Max Unit
RESOLUTION 16 Bits ANALOG INPUT Voltage Range, VIN VIN+ − VIN− = 0 V to 5 V −0.1 +5.1 V VIN+ − VIN− = 0 V to 10 V −0.1 +10.1 V VIN+ − VIN− = ±5 V −5.1 +5.1 V VIN+ − VIN− = ±10 V −10.1 +10.1 V VIN− to AGND −0.1 +0.1 V Analog Input CMRR fIN = 100 kHz 75 dB Input Current VIN = ±5 V, ±10 V @ 250 kSPS 1001 µA Input Impedance See Analog Inputs section THROUGHPUT SPEED Complete Cycle 4 μs Throughput Rate 250 kSPS DC ACCURACY Integral Linearity Error2 −1.5 ±0.75 +1.5 LSB3 No Missing Codes2 16 Bits Differential Linearity Error2 −1 +1.5 LSB Transition Noise 0.55 LSB Zero Error (Unipolar or Bipolar) −35 +35 LSB Zero Error Temperature Drift ±1 ppm/°C Bipolar Full-Scale Error −50 +50 LSB Unipolar Full-Scale Error −70 +70 LSB Full-Scale Error Temperature Drift ±1 ppm/°C Power Supply Sensitivity AVDD = 5 V ± 5% 3 LSB AC ACCURACY Dynamic Range VIN = 0 V to 5 V, fIN = 2 kHz, −60 dB 92.5 93.5 dB4 VIN = 0 V to 10 V, ±5 V, fIN = 2 kHz, −60 dB 94 dB VIN = ±10 V, fIN = 2 kHz, −60 dB 94.5 dB Signal-to-Noise Ratio VIN = 0 V to 5 V, 0 V to 10 V, fIN = 2 kHz 92 93 dB VIN = ±5 V, ±10 V, fIN = 2 kHz 94 dB VIN = 0 V to 5 V, fIN = 20 kHz 93.5 dB Signal-to-(Noise + Distortion) (SINAD) VIN = ±5 V, fIN = 2 kHz 92.5 dB VIN = 0 V to 10 V, ±5 V, fIN = 2 kHz 93 dB VIN = ±10 V, fIN = 2 kHz 93.5 dB Total Harmonic Distortion fIN = 2 kHz −107 dB Spurious-Free Dynamic Range fIN = 2 kHz 107 dB –3 dB Input Bandwidth VIN = 0 V to 5 V 650 kHz Aperture Delay 2 ns Aperture Jitter 5 ps rms Transient Response Full-scale step 500 ns INTERNAL REFERENCE PDREF = PDBUF = low Output Voltage REF @ 25°C 4.965 5.000 5.035 V Temperature Drift –40°C to +85°C ±3 ppm/°C Line Regulation AVDD = 5 V ± 5% ±15 ppm/V Long-Term Drift 1000 hours 50 ppm Turn-On Settling Time CREF = 22 µF 10 ms REFERENCE BUFFER PDREF = high REFBUFIN Input Voltage Range 2.4 2.5 2.6 V Rev. A | Page 3 of 32 Document Outline Features Functional Block Diagram Applications General Description Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Overview Converter Operation Transfer Functions Typical Connection Diagram Analog Inputs Input Range Selection Input Structure Voltage Reference Input/Output Internal Reference (REF = 5 V) (PDREF = Low, PDBUF = Low) External 2.5 V Reference and Internal Buffer (REF = 5 V) (PDREF = High, PDBUF = Low) External 5 V Reference (PDREF = High, PDBUF = High) Reference Decoupling Temperature Sensor Power Supplies Core Supplies High Voltage Supplies Digital Output Supply Power Sequencing Power Dissipation vs. Throughput Power Down Conversion Control Interfaces Digital Interface RESET Parallel Interface Master Parallel Interface Slave Parallel Interface 8-Bit Interface (Master or Slave) Serial Interface Data Interface Master Serial Interface Internal Clock (SER/ = High, EXT/ = Low) Read After Convert (RDC = Low, DIVSCLK[1:0] = [0 to 3]) Read During Convert (RDC = High) Slave Serial Interface External Clock (SER/ = High, EXT/ = High) External Discontinuous Clock Data Read After Conversion Daisy-Chain Feature External Clock Data Read During Previous Conversion External Clock Data Read After/During Conversion Hardware Configuration Software Configuration Microprocessor Interfacing SPI Interface Application Information Layout Guidelines Evaluating Performance Outline Dimensions Ordering Guide
