Datasheet AD7610 (Analog Devices) - 9
Description16-Bit, 250 kSPS, Unipolar/Bipolar Programmable Input PulSAR ADC
Pages / Page33 / 9 — AD7610. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. BUF. …
File Format / SizePDF / 694 Kb
AD7610. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. BUF. DBUF. DRE. EMP. IN+. VEE. IN–. 48 47 46. 45 44 43 42. 41 40 39 38 37
AD7610 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS BUF DBUF DRE EMP IN+ VEE IN– 48 47 46 45 44 43 42 41 40 39 38 37
link to page 11 link to page 11
AD7610 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS IN F ND BUF G F DD ND F F DBUF DRE EMP CC P P RE T AV IN+ AG VEE V IN– RE RE 48 47 46 45 44 43 42 41 40 39 38 37 AGND 1 36 BIPOLAR AVDD PIN 1 2 35 CNVST AGND 3 34 PD BYTESWAP 4 33 RESET OB/2C 5 AD7610 32 CS OGND 6 TOP VIEW 31 RD (Not to Scale) OGND 7 30 TEN SER/PAR 8 29 BUSY D0 9 28 D15/SCCS D1 10 27 D14/SCCLK D2/DIVSCLK[0] 11 26 D13/SCIN D3/DIVSCLK[1] 12 25 D12/HW/SW 13 14 15 16 17 18 19 20 21 22 23 24 T K N D K R NC DI DD DD ND UT NC T/IN Y CL S V Y X S S OGN O DV DG DO DCL S RRO S S /E 4 INV INV RDC/ D10/ D D8/ D9/ RDE D5/ D6/ D7/ D11/ NOTES 1. FOR THE LEAD FRAME CHIP SCALE PACKAGE (LFCSP), THE EXPOSED
004
PAD SHOULD BE CONNECTED TO VEE. THIS CONNECTION IS NOT REQUIRED TO MEET THE ELECTRICAL PERFORMANCES.
06395- Figure 4. Pin Configuration
Table 6. Pin Function Descriptions Pin No. Mnemonic Type1 Description
1, 3, 42 AGND P Analog Power Ground Pins. Ground reference point for all analog I/O. All analog I/O should be referenced to AGND and should be connected to the analog ground plane of the system. In addition, the AGND, DGND, and OGND voltages should be at the same potential. 2, 44 AVDD P Analog Power Pins. Nominally 4.75 V to 5.25 V and decoupled with 10 μF and 100 nF capacitors. 4 BYTESWAP DI Parallel Mode Selection (8-Bit/16-Bit). When high, the LSB is output on D[15:8] and the MSB is output on D[7:0]; when low, the LSB is output on D[7:0] and the MSB is output on D[15:8]. 5 OB/2C DI2 Straight Binary/Binary Twos Complement Output. When high, the digital output is straight binary. When low, the MSB is inverted resulting in a twos complement output from its internal shift register. 6, 7, 17 OGND P Input/Output Interface Digital Power Ground. Ground reference point for digital outputs. Should be connected to the system digital ground ideally at the same potential as AGND and DGND. 8 SER/PAR DI Serial/Parallel Selection Input. When SER/PAR = low, the parallel mode is selected. When SER/PAR = high, the serial modes are selected. Some bits of the data bus are used as a serial port and the remaining data bits are high impedance outputs. 9, 10 D[0:1] DO Bit 0 and Bit 1 of the parallel port data output bus. These pins are always outputs regardless of the state of SER/PAR. 11, 12 D[2:3] or DI/O In parallel mode, these outputs are used as Bit 2 and Bit 3 of the parallel port data output bus. DIVSCLK[0:1] Serial Data Division Clock Selection. In serial master read after convert mode (SER/PAR = high, EXT/INT = low, RDC/SDIN = low) these inputs can be used to slow down the internally generated serial data clock that clocks the data output. In other serial modes, these pins are high impedance outputs. 13 D4 or DI/O In parallel mode, this output is used as Bit 4 of the parallel port data output bus. EXT/INT Serial Data Clock Source Select. In serial mode, this input is used to select the internally generated (master) or external (slave) serial data clock for the AD7610 output data. When EXT/INT = low, master mode; the internal serial data clock is selected on SDCLK output. When EXT/INT = high, slave mode; the output data is synchronized to an external clock signal (gated by CS) connected to the SDCLK input. Rev. A | Page 8 of 32 Document Outline Features Functional Block Diagram Applications General Description Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Overview Converter Operation Transfer Functions Typical Connection Diagram Analog Inputs Input Range Selection Input Structure Voltage Reference Input/Output Internal Reference (REF = 5 V) (PDREF = Low, PDBUF = Low) External 2.5 V Reference and Internal Buffer (REF = 5 V) (PDREF = High, PDBUF = Low) External 5 V Reference (PDREF = High, PDBUF = High) Reference Decoupling Temperature Sensor Power Supplies Core Supplies High Voltage Supplies Digital Output Supply Power Sequencing Power Dissipation vs. Throughput Power Down Conversion Control Interfaces Digital Interface RESET Parallel Interface Master Parallel Interface Slave Parallel Interface 8-Bit Interface (Master or Slave) Serial Interface Data Interface Master Serial Interface Internal Clock (SER/ = High, EXT/ = Low) Read After Convert (RDC = Low, DIVSCLK[1:0] = [0 to 3]) Read During Convert (RDC = High) Slave Serial Interface External Clock (SER/ = High, EXT/ = High) External Discontinuous Clock Data Read After Conversion Daisy-Chain Feature External Clock Data Read During Previous Conversion External Clock Data Read After/During Conversion Hardware Configuration Software Configuration Microprocessor Interfacing SPI Interface Application Information Layout Guidelines Evaluating Performance Outline Dimensions Ordering Guide
