Datasheet AD7796, AD7797 (Analog Devices) - 6
DescriptionLow Power 24-Bit Sigma-Delta A/D Converter for Bridge Sensors
Pages / Page24 / 6 — AD7796/AD7797. Data Sheet. TIMING DIAGRAMS. CS (I). DOUT/RDY (O). MSB. …
File Format / SizePDF / 483 Kb
AD7796/AD7797. Data Sheet. TIMING DIAGRAMS. CS (I). DOUT/RDY (O). MSB. LSB. SCLK (I). I = INPUT, O = OUTPUT. t10. DIN (I). I = INPUT
AD7796/AD7797 Data Sheet TIMING DIAGRAMS CS (I) DOUT/RDY (O) MSB LSB SCLK (I) I = INPUT, O = OUTPUT t10 DIN (I) I = INPUT
AD7796/AD7797 Data Sheet TIMING DIAGRAMS CS (I) t6 t1 t5 DOUT/RDY (O) MSB LSB t t7 2 t3 SCLK (I) t4
003
06083- Figure 3. Read Cycle Timing Diagram
CS (I) t t 8 11 SCLK (I) t9 t10 DIN (I) MSB LSB
004
I = INPUT
06083- Figure 4. Write Cycle Timing Diagram Rev. B | Page 6 of 24 Document Outline FEATURES INTERFACE APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING CHARACTERISTICS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS RMS NOISE AND RESOLUTION SPECIFICATIONS TYPICAL PERFORMANCE CHARACTERISTICS ON-CHIP REGISTERS COMMUNICATION REGISTER RS2, RS1, RS0 = 0, 0, 0 STATUS REGISTER RS2, RS1, RS0 = 0, 0, 0; Power-On/Reset = 0x80 MODE REGISTER RS2, RS1, RS0 = 0, 0, 1; Power-On/Reset = 0x000A CONFIGURATION REGISTER RS2, RS1, RS0 = 0, 1, 0; Power-On/Reset = 0x0710 DATA REGISTER RS2, RS1, RS0 = 0, 1, 1; Power-On/Reset = 0x0000 (AD7796)/0x000000 (AD7797) ID REGISTER RS2, RS1, RS0 = 1, 0, 0; Power-On/Reset = 0x5A (AD7796)/0x5B (AD7797) OFFSET REGISTER RS2, RS1, RS0 = 1, 1, 0; Power-On/Reset = 0x8000 (AD7796)/0x800000 (AD7797) FULL-SCALE REGISTER RS2, RS1, RS0 = 1, 1, 1; Power-On/Reset = 0x5XXX (AD7796)/0x5XXX00 (AD7797) ADC CIRCUIT INFORMATION OVERVIEW DIGITAL INTERFACE Single Conversion Mode Continuous Conversion Mode Continuous Read Mode CIRCUIT DESCRIPTION ANALOG INPUT CHANNEL BIPOLAR/UNIPOLAR CONFIGURATION DATA OUTPUT CODING REFERENCE RESET BURNOUT CURRENTS AVDD MONITOR TEMPERATURE MONITOR CALIBRATION GROUNDING AND LAYOUT APPLICATIONS INFORMATION WEIGH SCALES OUTLINE DIMENSIONS ORDERING GUIDE
