Datasheet AD7643 (Analog Devices) - 9
Description18-Bit, 1.25 MSPS PulSAR® A/D Converter
Pages / Page29 / 9 — AD7643. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. BUF. DBUF. DRE. 48 …
File Format / SizePDF / 537 Kb
AD7643. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. BUF. DBUF. DRE. 48 47 46 45 44 43 42 41 40 39 38 37. AGND 1. 36 AGND. PIN 1. AVDD 2
AD7643 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS BUF DBUF DRE 48 47 46 45 44 43 42 41 40 39 38 37 AGND 1 36 AGND PIN 1 AVDD 2
link to page 11 link to page 11 link to page 11
AD7643 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS IN F ND BUF P D G F M D ND ND F F DBUF DRE + P P RE TE AV IN AG AG NC IN RE RE 48 47 46 45 44 43 42 41 40 39 38 37 AGND 1 36 AGND PIN 1 AVDD 2 IDENTIFIER 35 CNVST MODE0 3 34 PD MODE1 4 33 RESET D0/OB/2C 5 32 CS DGND 6 AD7643 31 RD TOP VIEW DGND 7 30 (Not to Scale) DGND D1/A0 8 29 BUSY D2/A1 9 28 D17 D3 10 27 D16 D4/DIVSCLK[0] 11 26 D15 D5/DIVSCLK[1] 12 25 D14 13 14 15 16 17 18 19 20 21 22 23 24 NC = NO CONNECT T C K IN D D T K R /IN N L D D DD ND U L NC T Y C O C Y X S S /S DV V D C OGN OV DG /S RRO /S 1/S 6/E INV D D1 D 8/IN D12 RDE
04 0
D7/ D 9/R D10 D 13/
4-
D
02 06 Figure 4. Pin Configuration
Table 6. Pin Function Descriptions Pin No. Mnemonic Type
1
1, 36, AGND P Analog Power Ground Pin. 41, 42 2, 44 AVDD P Input Analog Power Pins. Nominally 2.5 V. 3, 4 MODE[0:1] DI Data Output Interface Mode Selection.
Interface MODE# MODE1 MODE0 Description
0 0 0 18-bit interface 1 0 1 16-bit interface 2 1 0 8-bit (byte) interface 3 1 1 Serial interface 5 D0/OB/2C DI/O When MODE[1:0] = 0 (18-bit interface mode), this pin is Bit 0 of the parallel port data output bus and the data coding is straight binary. In all other modes, this pin allows the choice of straight binary/twos complement. When OB/2C is high, the digital output is straight binary; when low, the MSB is inverted resulting in a twos complement output from its internal shift register. 6, 7 DGND P Connect to Digital Ground. 8 D1/A0 DI/O When MODE[1:0] = 0, this pin is Bit 1 of the parallel port data output bus. In all other modes, this input pin controls the form in which data is output as shown in Table 7. 9 D2/A1 DI/O When MODE[1:0] = 0, this pin is Bit 2 of the parallel port data output bus. When MODE[1:0] = 1 or 2, this input pin controls the form in which data is output as shown in Table 7. 10 D3 DO When MODE[1:0] = 0, 1, or 2, this output is used as Bit 3 of the parallel port data output bus. This pin is always an output, regardless of the interface mode. 11, 12 D[4:5] DI/O When MODE[1:0] = 0, 1, or 2, these pins are Bit 4 and Bit 5 of the parallel port data output bus. or DIVSCLK[0:1] When MODE[1:0] = 3 (serial mode), serial clock division selection. When using serial master read after convert mode (EXT/INT = low, RDC/SDIN = low), these inputs can be used to slow down the internally generated serial clock that clocks the data output. In other serial modes, these pins are high impedance outputs. 13 D6 DI/O When MODE[1:0] = 0, 1, or 2, this output is used as Bit 6 of the parallel port data output bus. or EXT/INT When MODE[1:0] = 3 (serial mode), serial clock source select. This input is used to select the internally generated (master) or external (slave) serial data clock. When EXT/INT = low, master mode. The internal serial clock is selected on SCLK output. When EXT/INT = high, slave mode. The output data is synchronized to an external clock signal, gated by CS, connected to the SCLK input. Rev. 0 | Page 8 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION CIRCUIT INFORMATION CONVERTER OPERATION TRANSFER FUNCTIONS TYPICAL CONNECTION DIAGRAM ANALOG INPUTS MULTIPLEXED INPUTS DRIVER AMPLIFIER CHOICE Single-to-Differential Driver VOLTAGE REFERENCE INPUT Internal Reference (PDBUF = Low, PDREF = Low) External 1.2 V Reference and Internal Buffer (PDBUF = Low, PDREF = High) External 2.5 V Reference (PDBUF = High, PDREF = High) Reference Decoupling Temperature Sensor POWER SUPPLY Power Sequencing Power-Up CONVERSION CONTROL INTERFACES DIGITAL INTERFACE RESET PARALLEL INTERFACE Master Parallel Interface Slave Parallel Interface 16-Bit and 8-Bit Interface (Master or Slave) SERIAL INTERFACE MASTER SERIAL INTERFACE Internal Clock SLAVE SERIAL INTERFACE External Clock External Discontinuous Clock Data Read After Conversion External Clock Data Read During Previous Conversion MICROPROCESSOR INTERFACING SPI Interface (ADSP-219x) APPLICATION HINTS LAYOUT EVALUATING THE AD7643 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
