Datasheet AD7329 (Analog Devices) - 2
Description1 MSPS , 8-Channel, Software Selectable True Bipolar Input, 12-Bit Plus Sign A/D Converter
Pages / Page39 / 2 — AD7329* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 857 Kb
AD7329* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD7329* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD7329 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD7329 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all AD7329 EngineerZone Discussions. • AN-0972: How the AD7329 Helps Reduce Costs
Data Sheet SAMPLE AND BUY
• AD7329: 1 MSPS, 8-Channel, Software-Selectable, True Visit the product page to see pricing options. Bipolar Input, 12-Bit Plus Sign ADC Data Sheet
User Guides TECHNICAL SUPPORT
• UG-526: Evaluating the AD7329 1 MSPS, 12-Bit Plus Sign Submit a technical question or find your regional support ADC number.
REFERENCE MATERIALS DOCUMENT FEEDBACK Technical Articles
Submit feedback for this data sheet. • Maximizing Eight-Channel Data-Acquisition System Performance Using a Single ADC Driver • MS-2210: Designing Power Supplies for High Speed ADC
Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION OUTPUT CODING TRANSFER FUNCTIONS ANALOG INPUT STRUCTURE TRACK-AND-HOLD SECTION TYPICAL CONNECTION DIAGRAM ANALOG INPUT Single-Ended Inputs True Differential Mode Pseudo Differential Inputs DRIVER AMPLIFIER CHOICE REGISTERS ADDRESSING REGISTERS CONTROL REGISTER SEQUENCE REGISTER RANGE REGISTERS SEQUENCER OPERATION REFERENCE VDRIVE TEMPERATURE INDICATOR MODES OF OPERATION NORMAL MODE(PM1 = PM0 = 0) FULL SHUTDOWN MODE(PM1 = PM0 = 1) AUTOSHUTDOWN MODE(PM1 = 1, PM0 = 0) AUTOSTANDBY MODE(PM1 = 0, PM0 =1) POWER VS. THROUGHPUT RATE SERIAL INTERFACE MICROPROCESSOR INTERFACING AD7329 TO ADSP-21xx AD7329 TO ADSP-BF53x APPLICATIONS INFORMATION LAYOUT AND GROUNDING POWER SUPPLY CONFIGURATION OUTLINE DIMENSIONS ORDERING GUIDE
