Datasheet AD9237 (Analog Devices) - 4
Description12-Bit, 20/40/65 MSPS 3 V Low Power A/D Converter
Pages / Page25 / 4 — Data Sheet. AD9237. SPECIFICATIONS DC SPECIFICATIONS. Table 1. …
RevisionC
File Format / SizePDF / 620 Kb
Data Sheet. AD9237. SPECIFICATIONS DC SPECIFICATIONS. Table 1. AD9237BCP-20. AD9237BCP-40. AD9237BCP-65. Parameter. Min. Typ. Max. Unit
Data Sheet AD9237 SPECIFICATIONS DC SPECIFICATIONS Table 1 AD9237BCP-20 AD9237BCP-40 AD9237BCP-65 Parameter Min Typ Max Unit
link to page 11
AVDD = 3 V, DRVDD = 2.5 V, maximum sample rate, 2 V p-p differential input, −0.5 dBFS input, 1.0 V internal reference, TMIN to TMAX, unless otherwise noted.
Table 1. AD9237BCP-20 AD9237BCP-40 AD9237BCP-65 Parameter Min Typ Max Min Typ Max Min Typ Max Unit
RESOLUTION 12 12 12 Bits ACCURACY No Missing Codes Guaranteed 12 12 12 Bits Offset Error ±1.30 ±1.95 ±1.30 ±1.95 ±1.30 ±1.95 % FSR Gain Error1 ±0.70 ±2.10 ±0.75 ±2.10 ±1.05 ±2.25 % FSR Differential Nonlinearity (DNL)2 ±0.70 ±0.95 ±0.70 ±0.95 −1.00 ±0.70 +1.25 LSB Integral Nonlinearity (INL)2 ±0.90 ±1.35 ±0.90 ±1.35 ±0.90 ±2.00 LSB TEMPERATURE DRIFT Offset Error ±2 ±2 ±2 ppm/°C Gain Error1 ±12 ±12 ±12 ppm/°C INTERNAL VOLTAGE REFERENCE Output Voltage Error (1 V Mode) ±5 ±25 ±5 ±25 ±5 ±25 mV Load Regulation @ 1.0 mA 0.8 0.8 0.8 mV Output Voltage Error (0.5 V Mode) ±2.5 ±2.5 ±2.5 mV Load Regulation @ 0.5 mA 0.1 0.1 0.1 mV Reference Input Resistance 7 7 7 kΩ INPUT REFERRED NOISE VREF = 0.5 V 1.35 1.35 1.35 LSB rms VREF = 1.0 V 0.70 0.70 0.70 LSB rms ANALOG INPUT Input Span VREF = 0.5 V; MODE2 = 0 V 1 1 1 V p-p VREF = 1.0 V; MODE2 = 0 V 2 2 2 V p-p VREF = 0.5 V; MODE2 = AVDD 2 2 2 V p-p VREF = 1.0 V; MODE2 = AVDD 4 4 4 V p-p Input Capacitance3 7 7 7 pF POWER SUPPLIES Supply Voltages AVDD 2.7 3.0 3.6 2.7 3.0 3.6 2.7 3.0 3.6 V DRVDD 2.25 2.5 3.6 2.25 2.5 3.6 2.25 2.5 3.6 V Supply Current IAVDD2 30.5 45.5 64.5 mA IDRVDD2 3.0 4.5 5.5 mA PSRR ±0.01 ±0.01 ±0.01 % FSR POWER CONSUMPTION DC Input4 85 135 190 mW Sine Wave Input2 100 120 150 180 210 270 mW Power-Down Mode 1 1 1 mW Standby Power 20 20 20 mW 1 Gain error and gain temperature coefficient are based on the ADC only (with a fixed 1.0 V external reference). 2 Measured at maximum clock rate, fIN = 2.4 MHz, ful -scale sine wave, with approximately 5 pF loading on each output bit. 3 Input capacitance refers to the effective capacitance between one differential input pin and AGND. Refer to Figure 4 for the equivalent analog input structure. 4 Measured with dc input at maximum clock rate. Rev. C | Page 3 of 24 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications DC Specifications Digital Specifications AC Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Terminology Equivalent Circuits Typical Performance Characteristics Applying the AD9237 Theory of Operation Analog Input and Reference Overview Differential Input Configurations Single-Ended Input Configuration Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Power Dissipation, Power Scaling, and Standby Mode Digital Outputs Operational Mode Selection Out of Range (OTR) Digital Output Enable Function (OE) Timing Outline Dimensions Ordering Guide
