Datasheet AD9237 (Analog Devices) - 7
Description12-Bit, 20/40/65 MSPS 3 V Low Power A/D Converter
Pages / Page25 / 7 — AD9237. Data Sheet. TIMING DIAGRAM. N+1. N+2. N+8. N–1. N+3. ANALOG. …
RevisionC
File Format / SizePDF / 620 Kb
AD9237. Data Sheet. TIMING DIAGRAM. N+1. N+2. N+8. N–1. N+3. ANALOG. INPUT. N+7. N+4. N+5. N+6. CLK. DATA. N–11. N–10. N–9. N–8. N–7. N–6. N–5. N–4. N–3. N–2. OUT. tPD
AD9237 Data Sheet TIMING DIAGRAM N+1 N+2 N+8 N–1 N+3 ANALOG INPUT N+7 N+4 N+5 N+6 CLK DATA N–11 N–10 N–9 N–8 N–7 N–6 N–5 N–4 N–3 N–2 OUT tPD
AD9237 Data Sheet TIMING DIAGRAM N+1 N N+2 N+8 N–1 N+3 ANALOG tA INPUT N+7 N+4 N+5 N+6 CLK DATA N–11 N–10 N–9 N–8 N–7 N–6 N–5 N–4 N–3 N–2 N–1 OUT
2 00 5-
tPD
45 05 Figure 2. Timing Diagram Rev. C | Page 6 of 24 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications DC Specifications Digital Specifications AC Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Terminology Equivalent Circuits Typical Performance Characteristics Applying the AD9237 Theory of Operation Analog Input and Reference Overview Differential Input Configurations Single-Ended Input Configuration Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Power Dissipation, Power Scaling, and Standby Mode Digital Outputs Operational Mode Selection Out of Range (OTR) Digital Output Enable Function (OE) Timing Outline Dimensions Ordering Guide
