Datasheet AD7328 (Analog Devices) - 4
DescriptionSoftware Selectable, True Bipolar Input, 8-Channel, 12-Bit Plus Sign A/D Converter
Pages / Page37 / 4 — Data Sheet. AD7328. SPECIFICATIONS. Table 2. B Version. Parameter1. Min. …
RevisionC
File Format / SizePDF / 773 Kb
Data Sheet. AD7328. SPECIFICATIONS. Table 2. B Version. Parameter1. Min. Typ. Max. Unit. Test Conditions/Comments
Data Sheet AD7328 SPECIFICATIONS Table 2 B Version Parameter1 Min Typ Max Unit Test Conditions/Comments
link to page 12 link to page 11 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6
Unless otherwise noted, VDD = 12 V to 16.5 V, VSS = −12 V to −16.5 V, VCC = 4.75 V to 5.25 V, VDRIVE = 2.7 V to 5.25 V, VREF = 2.5 V to 3.0 V internal/external, fSCLK = 20 MHz, fS = 1 MSPS, TA = TMAX to TMIN. With VCC < 4.75 V, al specifications are typical.
Table 2. B Version Parameter1 Min Typ Max Unit Test Conditions/Comments
DYNAMIC PERFORMANCE fIN = 50 kHz sine wave Signal-to-Noise Ratio (SNR) 76 dB Differential mode 72.5 dB Single-ended/pseudo differential mode Signal-to-Noise and Distortion 75 dB Differential mode; ±2.5 V and ±5 V ranges (SINAD)2 76 dB Differential mode; 0 V to +10 V and ±10 V ranges 72 dB Single-ended/pseudo differential mode; ±2.5 V and ±5 V ranges 72.5 dB Single-ended/pseudo differential mode; 0 V to +10 V and ±10 V ranges Total Harmonic Distortion (THD)2 −80 dB Differential mode; ±2.5 V and ±5 V ranges −82 dB Differential mode; 0 V to +10 V and ±10 V ranges −77 dB Single-ended/pseudo differential mode; ±2.5 V and ±5 V ranges −80 dB Single-ended/pseudo differential mode; 0 V to +10 V and ±10 V ranges Peak Harmonic or Spurious Noise −80 dB Differential mode; ±2.5 V and ±5 V ranges (SFDR)2 −82 dB Differential mode; 0 V to +10 V and ±10 V ranges −78 dB Single-ended/pseudo differential mode; ±2.5 V and ±5 V ranges −79 dB Single-ended/pseudo differential mode; 0 V to +10 V and ±10 V ranges Intermodulation Distortion (IMD)2 fa = 50 kHz, fb = 30 kHz Second-Order Terms −88 dB Third-Order Terms −90 dB Aperture Delay3 7 ns Aperture Jitter3 50 ps Common-Mode Rejection Ratio −79 dB Up to 100 kHz ripple frequency; see Figure 17 (CMRR)2 Channel-to-Channel Isolation2 −72 dB fIN on unselected channels up to 100 kHz; see Figure 14 Full Power Bandwidth 22 MHz At 3 dB 5 MHz At 0.1 dB DC ACCURACY4 All specifications are typical for 0 V to 10 V mode Single-ended/pseudo differential mode 1 LSB = FSR/4096, unless otherwise noted Differential mode 1 LSB = FSR/8192, unless otherwise noted Resolution 13 Bits No Missing Codes 12-bit Bits Differential mode plus sign (13 bits) 11-bit Bits Single-ended/pseudo differential mode plus sign (12 bits) Integral Nonlinearity2 ±1.1 LSB Differential mode ±1 LSB Single-ended/pseudo differential mode −0.7/+1.2 LSB Single-ended/pseudo differential mode (LSB = FSR/8192) Rev. C | Page 3 of 36 Document Outline Features General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Output Coding Transfer Functions Analog Input Structure Track-and-Hold Section Typical Connection Diagram Analog Input Single-Ended Inputs True Differential Mode Pseudo Differential Inputs Driver Amplifier Choice Registers Addressing Registers Control Register Sequence Register Range Registers Sequencer Operation Reference VDRIVE Temperature Indicator Modes of Operation Normal Mode (PM1 = PM0 = 0) Full Shutdown Mode (PM1 = PM0 = 1) Autoshutdown Mode (PM1 = 1, PM0 = 0) Autostandby Mode (PM1 = 0, PM0 = 1) Power vs. Throughput Rate Serial Interface Microprocessor Interfacing AD7328 to ADSP-21xx AD7328 to ADSP-BF53x Applications Information Layout and Grounding Power Supply Configuration Outline Dimensions Ordering Guide
