Datasheet AD7623 (Analog Devices) - 2
Description16-Bit, 1.33 MSPS PulSAR® A/D Converter
Pages / Page29 / 2 — AD7623* PRODUCT PAGE QUICK LINKS Last Content Update: 04/14/2017. …
File Format / SizePDF / 449 Kb
AD7623* PRODUCT PAGE QUICK LINKS Last Content Update: 04/14/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD7623* PRODUCT PAGE QUICK LINKS Last Content Update: 04/14/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD7623 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD7623 Evaluation Kit • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all AD7623 EngineerZone Discussions. • AN-931: Understanding PulSAR ADC Support Circuitry • AN-932: Power Supply Sequencing
SAMPLE AND BUY Data Sheet
Visit the product page to see pricing options. • AD7623: 16-Bit, 1.33 MSPS PulSAR® ADC Data Sheet
TECHNICAL SUPPORT TOOLS AND SIMULATIONS
Submit a technical question or find your regional support • AD7623 IBIS Models number.
REFERENCE MATERIALS DOCUMENT FEEDBACK Technical Articles
Submit feedback for this data sheet. • MS-2210: Designing Power Supplies for High Speed ADC
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING SPECIFICATIONS SERIAL CLOCK TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION TRANSFER FUNCTIONS TYPICAL CONNECTION DIAGRAM ANALOG INPUTS DRIVER AMPLIFIER CHOICE Single-to-Differential Driver VOLTAGE REFERENCE INPUT Internal Reference (PDBUF = Low, PDREF = Low) External 1.2 V Reference and Internal Buffer (PDREF = High, PBBUF = Low) External Reference (PDBUF = High, PRBUF = High) Reference Decoupling Temperature Sensor POWER SUPPLY Power Sequencing Power-Up POWER DISSIPATION VS. THROUGHPUT CONVERSION CONTROL INTERFACES DIGITAL INTERFACE RESET PARALLEL INTERFACE Master Parallel Interface Slave Parallel Interface 8-Bit Interface (Master or Slave) SERIAL INTERFACE MASTER SERIAL INTERFACE Internal Clock SLAVE SERIAL INTERFACE External Clock External Discontinuous Clock Data Read After Conversion External Clock Data Read During Previous Conversion MICROPROCESSOR INTERFACING SPI Interface (ADSP-219x) APPLICATION LAYOUT EVALUATING THE AD7623 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
