Datasheet AD9229 (Analog Devices) - 2
DescriptionQuad 12-Bit, 50/65 MSPS, Serial LVDS A/D Converter
Pages / Page41 / 2 — AD9229* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 799 Kb
AD9229* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. DOCUMENTATION
AD9229* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS DOCUMENTATION
View a parametric search of comparable parts. • Visual Analog • AD9229 IBIS Models
DOCUMENTATION Application Notes REFERENCE MATERIALS
• AN-1142: Techniques for High Speed ADC PCB Layout
Technical Articles
• AN-282: Fundamentals of Sampled Data Systems • Correlating High-Speed ADC Performance to Multicarrier • AN-345: Grounding for Low-and-High-Frequency Circuits 3G Requirements • AN-501: Aperture Uncertainty and ADC System • High-speed ADCs: Preventing Front-end Collisions Performance • Matching An ADC To A Transformer • AN-586: LVDS Outputs for High Speed A/D Converters • MS-2210: Designing Power Supplies for High Speed ADC • AN-715: A First Approach to IBIS Models: What They Are and How They Are Generated
DESIGN RESOURCES
• AN-737: How ADIsimADC Models an ADC • AD9229 Material Declaration • AN-741: Little Known Characteristics of Phase Noise • PCN-PDN Information • AN-756: Sampled Systems and the Effects of Clock Phase • Quality And Reliability Noise and Jitter • Symbols and Footprints • AN-808: Multicarrier CDMA2000 Feasibility • AN-827: A Resonant Approach to Interfacing Amplifiers to
DISCUSSIONS
Switched-Capacitor ADCs View all AD9229 EngineerZone Discussions. • AN-835: Understanding High Speed ADC Testing and Evaluation
SAMPLE AND BUY
• AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual Visit the product page to see pricing options.
Data Sheet TECHNICAL SUPPORT
• AD9229: Quad, 12-Bit, 50/65 MSPS, Serial LVDS 3 V A/D Converter Data Sheet Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Differential Input Configurations Single-Ended Input Configuration CLOCK INPUT CONSIDERATIONS Power Dissipation and Power-Down Mode Digital Outputs Timing DTP Pin Voltage Reference Internal Reference Connection External Reference Operation Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations EVALUATION BOARD POWER SUPPLIES INPUT SIGNALS OUTPUT SIGNALS DEFAULT OPERATION AND JUMPER SELECTION SETTINGS ALTERNATE ANALOG INPUT DRIVE CONFIGURATION OUTLINE DIMENSIONS ORDERING GUIDE
