Datasheet AD7265 (Analog Devices) - 2
DescriptionDifferential/Single-Ended Input, Dual 1 MSPS, 12-Bit, 3-Channel SAR A/D Converter
Pages / Page29 / 2 — AD7265* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 824 Kb
AD7265* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD7265* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD7265 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD7265 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all AD7265 EngineerZone Discussions. • AD7265: Differential/Single-Ended Input, Dual 1 MSPS, 12- Bit, 3-Channel SAR ADC Data Sheet
SAMPLE AND BUY
Visit the product page to see pricing options.
SOFTWARE AND SYSTEMS REQUIREMENTS
• AD7266 Differential/Single-Ended Input, Dual,
TECHNICAL SUPPORT
Simultaneous Sampling, 2 MSPS, 12-Bit, 3-Channel SAR A/ D Converter Linux Driver Submit a technical question or find your regional support number.
REFERENCE DESIGNS DOCUMENT FEEDBACK
• CN0048 Submit feedback for this data sheet.
REFERENCE MATERIALS Press
• Dual-Supply, High-Precision Operational Amplifier Designed for Front-End Amplifier Applications
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION ANALOG INPUT STRUCTURE ANALOG INPUTS Single-Ended Mode Differential Mode Driving Differential Inputs Using an Op Amp Pair Pseudo Differential Mode ANALOG INPUT SELECTION OUTPUT CODING TRANSFER FUNCTIONS DIGITAL INPUTS VDRIVE MODES OF OPERATION NORMAL MODE PARTIAL POWER-DOWN MODE FULL POWER-DOWN MODE POWER-UP TIMES POWER vs. THROUGHPUT RATE SERIAL INTERFACE MICROPROCESSOR INTERFACING AD7265 TO ADSP-218x AD7265 to ADSP-BF53x AD7265 TO TMS320C541 AD7265 TO DSP563xx APPLICATION HINTS GROUNDING AND LAYOUT PCB DESIGN GUIDELINES FOR LFCSP EVALUATING THE AD7265 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
