Datasheet AD9481 (Analog Devices) - 7
Description8-Bit, 250 MSPS, 3.3 V A/D Converter
Pages / Page29 / 7 — AD9481. SWITCHING SPECIFICATIONS. Table 4. AD9481-250. Parameter. Temp …
File Format / SizePDF / 736 Kb
AD9481. SWITCHING SPECIFICATIONS. Table 4. AD9481-250. Parameter. Temp Test. Level. Min Typ Max Unit
AD9481 SWITCHING SPECIFICATIONS Table 4 AD9481-250 Parameter Temp Test Level Min Typ Max Unit
link to page 7 link to page 7 link to page 7 link to page 7 link to page 7
AVDD = 3.3 V, DRVDD = 3.3 V; differential encode input, duty cycle stabilizer enabled, unless otherwise noted.
Table 4. AD9481-250 Parameter Temp Test Level Min Typ Max Unit
CLOCK Maximum Conversion Rate Full VI 250 MSPS Minimum Conversion Rate Full IV 20 MSPS Clock Pulse-Width High (tEH) Full IV 1.2 2 ns Clock Pulse-Width Low (tEL) Full IV 1.2 2 ns DS Input Setup Time (tSDS) Full IV 0.5 ns DS Input Hold Time (tHDS) Full IV 0.5 ns OUTPUT PARAMETERS1 Valid Time (tV)2 Full VI 2.5 ns Propagation Delay (tPD) Full VI 4 5.4 ns Rise Time (tR) 10% to 90% Full V 670 ps Fall Time (tF) 10% to 90% Full V 360 ps DCO Propagation Delay (tCPD) 3 Full VI 2.5 3.9 5.3 ns Data-to-DCO Skew (tPD − tCPD)4 Full VI −0.5 +0.5 ns A Port Data to DCO− Rising (tSKA)5 Full IV 4 ns B Port Data to DCO+ Rising (tSKB) Full IV 4 ns Pipeline Latency (A, B) Full IV 8 Cycles APERTURE Aperture Delay (tA) 25°C V 1.5 ns Aperture Uncertainty (Jitter) 25°C V 0.25 ps rms OUT-OF-RANGE RECOVERY TIME 25°C V 1 Cycle 1 CLOAD equals 5 pF maximum for all output switching specifications. 2 Valid time is approximately equal to minimum tPD. 3 TCPD equals clock rising edge to DCO (+ or −) rising edge delay. 4 Data changing to (DCO+ or DCO−) rising edge delay. 5 TSKA, TSKB are both clock rate dependent delays equal to TCYCLE − (Data to DCO skew). Rev. 0 | Page 6 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS DC SPECIFICATIONS DIGITAL SPECIFICATIONS AC SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS APPLICATIONS ANALOG INPUTS VOLTAGE REFERENCE Fixed Reference External Reference Programmable Reference CLOCKING THE AD9481 DS INPUTS DIGITAL OUTPUTS INTERLEAVING TWO AD9481s DATA CLOCK OUT POWER-DOWN INPUT AD9481 EVALUATION BOARD POWER CONNECTOR ANALOG INPUTS GAIN OPTIONAL OPERATIONAL AMPLIFIER CLOCK OPTIONAL CLOCK BUFFER DS OPTIONAL XTAL VOLTAGE REFERENCE DATA OUTPUTS EVALUATION BOARD BILL OF MATERIALS (BOM) PCB SCHEMATICS PCB LAYERS OUTLINE DIMENSIONS ORDERING GUIDE
