Datasheet AD9480 (Analog Devices) - 2
Description8-Bit, 250 MSPS, 3.3 V A/D Converter
Pages / Page29 / 2 — AD9480* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 650 Kb
AD9480* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. DOCUMENTATION
AD9480* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS DOCUMENTATION
View a parametric search of comparable parts. • Visual Analog • AD9480 IBIS Models
DOCUMENTATION Application Notes REFERENCE MATERIALS
• AN-1142: Techniques for High Speed ADC PCB Layout
Technical Articles
• AN-282: Fundamentals of Sampled Data Systems • Correlating High-Speed ADC Performance to Multicarrier • AN-345: Grounding for Low-and-High-Frequency Circuits 3G Requirements • AN-501: Aperture Uncertainty and ADC System • MS-2210: Designing Power Supplies for High Speed ADC Performance • AN-586: LVDS Outputs for High Speed A/D Converters
DESIGN RESOURCES
• AN-715: A First Approach to IBIS Models: What They Are • AD9480 Material Declaration and How They Are Generated • PCN-PDN Information • AN-737: How ADIsimADC Models an ADC • Quality And Reliability • AN-741: Little Known Characteristics of Phase Noise • Symbols and Footprints • AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter
DISCUSSIONS
• AN-807: Multicarrier WCDMA Feasibility View all AD9480 EngineerZone Discussions. • AN-808: Multicarrier CDMA2000 Feasibility • AN-835: Understanding High Speed ADC Testing and
SAMPLE AND BUY
Evaluation Visit the product page to see pricing options. • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual
TECHNICAL SUPPORT
• AN-935: Designing an ADC Transformer-Coupled Front End Submit a technical question or find your regional support number.
Data Sheet
• AD9480: 8-Bit, 250 MSPS 3.3V A/D Converter Data Sheet
DOCUMENT FEEDBACK User Guides
Submit feedback for this data sheet. • UG-173: High Speed ADC USB FIFO Evaluation Kit (HSC- ADC-EVALB-DCZ)
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY DC SPECIFICATIONS DIGITAL SPECIFICATIONS AC SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS APPLICATION NOTES CLOCKING THE AD9480 ANALOG INPUTS VOLTAGE REFERENCE Fixed Reference External Reference Programmable Reference DIGITAL OUTPUTS OUTPUT CODING INTERLEAVING TWO AD9480s DATA CLOCK OUT POWER-DOWN AD9480 EVALUATION BOARD POWER CONNECTOR ANALOG INPUTS GAIN OPTIONAL OPERATIONAL AMPLIFIER CLOCK OPTIONAL CLOCK BUFFER OPTIONAL XTAL VOLTAGE REFERENCE DATA OUTPUTS EVALUATION BOARD BILL OF MATERIALS (BOM) PCB SCHEMATICS PCB LAYERS OUTLINE DIMENSIONS ORDERING GUIDE
