Datasheet AD7912, AD7922 (Analog Devices) - 6
Description2-Channel, 2.35 V to 5.25 V, 1 MSPS, 12-Bit A/D Converter
Pages / Page32 / 6 — AD7912/AD7922. Parameter A. Grade1. Unit. Test Conditions/Comments
File Format / SizePDF / 396 Kb
AD7912/AD7922 Parameter A Grade1 Unit Test Conditions/Comments
link to page 5 link to page 5 link to page 25 link to page 7
LOGIC OUTPUTS Output High Voltage, VOH VDD − 0.2 V min ISOURCE = 200 µA; VDD = 2.35 V to 5.25 V Output Low Voltage, VOL 0.2 V max ISINK = 200 µA Floating-State Leakage Current ±0.3 µA max Floating-State Output Capacitance3 5 pF max Output Coding Straight (natural) binary CONVERSION RATE Conversion Time 888 ns max 16 SCLK cycles with SCLK at 18 MHz Track-and-Hold Acquisition Time2 290 ns max Throughput Rate 1 MSPS max See the Serial Interface section POWER REQUIREMENTS VDD 2.35/5.25 V min/max IDD Digital I/Ps = 0 V or VDD Normal Mode (Static) 3 mA typ VDD = 4.75 V to 5.25 V, SCLK on or off 1.5 mA typ VDD = 2.35 V to 3.6 V, SCLK on or off Normal Mode (Operational) 4 mA max VDD = 4.75 V to 5.25 V, fSAMPLE = 1 MSPS 2 mA max VDD = 2.35 V to 3.6 V, fSAMPLE = 1 MSPS Full Power-Down Mode (Static) 1 µA max SCLK on or off, typically 50 nA Full Power-Down Mode (Dynamic) 0.5 mA typ VDD = 5 V, fSCLK = 18 MHz, fSAMPLE = 100 kSPS 0.28 mA typ VDD = 3 V, fSCLK = 18 MHz, fSAMPLE = 100 kSPS Power Dissipation4 Normal Mode (Operational) 20 mW max VDD = 5 V, fSAMPLE = 1 MSPS 6 mW max VDD = 3 V, fSAMPLE = 1 MSPS Full Power-Down 5 µW max VDD = 5 V 3 µW max VDD = 3 V 1 Operational from VDD = 2 V, with VIH = 1.9 V minimum and VIL = 0.1 V maximum. 2 See the Terminology section. 3 Guaranteed by characterization. 4 See the Power vs. Throughput Rate section. Rev. 0 | Page 6 of 32 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS AD7912 SPECIFICATIONS AD7922 SPECIFICATIONS TIMING SPECIFICATIONS TIMING DIAGRAMS TIMING EXAMPLES Timing Example 1 Timing Example 2 ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT INFORMATION CONVERTER OPERATION ADC TRANSFER FUNCTION TYPICAL CONNECTION DIAGRAM ANALOG INPUT DIGITAL INPUTS DIN INPUT DOUT OUTPUT MODES OF OPERATION NORMAL MODE POWER-DOWN MODE POWER-UP TIME DAISY-CHAIN MODE DAISY-CHAIN EXAMPLE POWER VS. THROUGHPUT RATE SERIAL INTERFACE MICROPROCESSOR INTERFACING AD7912/AD7922 to TMS320C541 Interface AD7912/AD7922 to ADSP-218x AD7912/AD7922 to DSP563xx Interface APPLICATION HINTS GROUNDING AND LAYOUT EVALUATING AD7912/AD7922 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
