AD7452* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017COMPARABLE PARTSDESIGN RESOURCES View a parametric search of comparable parts. • AD7452 Material Declaration • PCN-PDN Information DOCUMENTATION • Quality And Reliability Data Sheet • Symbols and Footprints • AD7452: Differential Input, 555 kSPS, 12-Bit ADC in an 8- Lead SOT-23 Data Sheet DISCUSSIONSProduct Highlight View all AD7452 EngineerZone Discussions. • 8- to 18-Bit SAR ADCs ... From the Leader in High Performance Analog SAMPLE AND BUY Visit the product page to see pricing options. REFERENCE MATERIALSTechnical ArticlesTECHNICAL SUPPORT • Maximize Performance When Driving Differential ADCs Submit a technical question or find your regional support • MS-2210: Designing Power Supplies for High Speed ADC number. DOCUMENT FEEDBACK Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT INFORMATION CONVERTER OPERATION ADC TRANSFER FUNCTION TYPICAL CONNECTION DIAGRAM ANALOG INPUT Analog Input Structure DRIVING DIFFERENTIAL INPUTS Differential Amplifier Op Amp Pair RF Transformer DIGITAL INPUTS REFERENCE Example 1 Example 2 SINGLE-ENDED OPERATION SERIAL INTERFACE Timing Example MODES OF OPERATION NORMAL MODE POWER-DOWN MODE POWER-UP TIME POWER vs. THROUGHPUT RATE APPLICATION HINTS Grounding and Layout EVALUATING THE AD7452’S PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
