Datasheet AD9215 (Analog Devices) - 3
Description10-Bit, 65/80/105 MSPS 3 V A/D Converter
Pages / Page37 / 3 — AD9215. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 2/13—Data Sheet …
AD9215. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 2/13—Data Sheet Changed from a REV. A to a REV. B
AD9215 Data Sheet TABLE OF CONTENTS REVISION HISTORY 2/13—Data Sheet Changed from a REV A to a REV B
link to page 4 link to page 7 link to page 7 link to page 7 link to page 8 link to page 9 link to page 9 link to page 11 link to page 15 link to page 16 link to page 19 link to page 34 link to page 35
Specifications ... 3
REVISION HISTORY
Absolute Maximum Ratings1 .. 6
Explanation of Test Levels ... 6 Changes to Figure 4 and Added EPAD Note to Pin Configura- tions and Function Descriptions Section ... 7 ESD Caution .. 6 Changes to Voltage Reference Section .. 17 Pin Configurations and Function Descriptions ... 7 Changes to Evaluation Board Section... 18 Equivalent Circuits ... 8 Updated Outline Dimensions .. 33 Definitions of Specifications ... 8 Changes to Ordering Guide ... 34 Typical Performance Characteristics ... 10
2/04—Data Sheet Changed from a REV. 0 to a REV. A
Applying the AD9215 Theory of Operation ... 14 Renumbered Figures and Tables ..UNIVERSAL Clock Input and Considerations .. 15 Changes to Product Title .. 1 Evaluation Board .. 18 Changes to Features .. 1 Outline Dimensions ... 33 Changes to Product Description ... 1 Ordering Guide ... 34 Changes to Product Highlights ... 1 Changes to Specifications ... 2 Changes to Figure 2 ... 4 Changes to Figures 9 to 11 ... 10 Added Figure 14 .. 10 Added Figures 16 and 18 .. 11 Changes to Figures 21 to 24 and 25 to 26 ... 12 Deleted Figure 25 ... 12 Changes to Figures 28 and 29 .. 13 Changes to Figure 31 ... 14 Changes t0 Figure 35 ... 16 Changes to Figures 50 through 58... 26 Added Table 11 .. 31 Updated Outline Dimensions .. 32 Changes to Ordering Guide ... 33
5/03—Revision 0: Initial Version
Rev. B | Page 2 of 36 Document Outline Specifications Absolute Maximum Ratings1 Explanation of Test Levels ESD Caution Pin Configurations and Function Descriptions Equivalent Circuits Definitions of Specifications Aperture Delay Aperture Jitter Clock Pulse Width and Duty Cycle Differential Nonlinearity (DNL, No Missing Codes) Effective Number of Bits (ENOB) Gain Error Integral Nonlinearity (INL) Maximum Conversion Rate Minimum Conversion Rate Offset Error Out-of-Range Recovery Time Output Propagation Delay Power Supply Rejection Signal-to-Noise and Distortion (SINAD) Ratio Signal-to-Noise Ratio (SNR) Spurious-Free Dynamic Range (SFDR) Temperature Drift Total Harmonic Distortion (THD) Two-Tone SFDR Typical Performance Characteristics Applying the AD9215 Theory of Operation Analog Input and Reference Overview Differential Input Configurations Single-Ended Input Configuration Clock Input and Considerations Power Dissipation and Standby Mode Digital Outputs Timing Voltage Reference Internal Reference Connection External Reference Operation Operational Mode Selection Evaluation Board Outline Dimensions Ordering Guide
