Datasheet AD9244 (Analog Devices) - 2
Description14-Bit 40/65 MSPS IF Sampling Analog-To-Digital Converter
Pages / Page37 / 2 — AD9244* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
RevisionC
AD9244* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9244* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9244 IBIS Models
EVALUATION KITS
• AD9244 Evaluation Board
REFERENCE MATERIALS Technical Articles DOCUMENTATION
• Buffer Adapts Single-ended Signals for Differential Inputs
Application Notes
• Correlating High-Speed ADC Performance to Multicarrier • AN-1142: Techniques for High Speed ADC PCB Layout 3G Requirements • AN-282: Fundamentals of Sampled Data Systems • DNL and Some of its Effects on Converter Performance • AN-345: Grounding for Low-and-High-Frequency Circuits • Matching An ADC To A Transformer • AN-501: Aperture Uncertainty and ADC System • MS-2210: Designing Power Supplies for High Speed ADC Performance • AN-715: A First Approach to IBIS Models: What They Are
DESIGN RESOURCES
and How They Are Generated • AD9244 Material Declaration • AN-737: How ADIsimADC Models an ADC • PCN-PDN Information • AN-741: Little Known Characteristics of Phase Noise • Quality And Reliability • AN-742: Frequency Domain Response of Switched- • Symbols and Footprints Capacitor ADCs • AN-756: Sampled Systems and the Effects of Clock Phase
DISCUSSIONS
Noise and Jitter View all AD9244 EngineerZone Discussions. • AN-807: Multicarrier WCDMA Feasibility • AN-808: Multicarrier CDMA2000 Feasibility
SAMPLE AND BUY
• AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs Visit the product page to see pricing options. • AN-835: Understanding High Speed ADC Testing and Evaluation
TECHNICAL SUPPORT
• AN-905: Visual Analog Converter Evaluation Tool Version Submit a technical question or find your regional support 1.0 User Manual number. • AN-935: Designing an ADC Transformer-Coupled Front End
DOCUMENT FEEDBACK Data Sheet
Submit feedback for this data sheet. • AD9244: 14-Bit, 40/65 MSPS A/D Converter Data Sheet
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL APPLICATION CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT AND REFERENCE OVERVIEW ANALOG INPUT OPERATION Single-Ended Input Configuration Differentially Driving the Analog Inputs REFERENCE OPERATION Pin-Programmable Reference Resistor-Programmable Reference Using an External Reference Digital Outputs Data Format Select (DFS) Digital Output Driver Considerations DIGITAL INPUTS AND OUTPUTS Out of Range (OTR) Digital Output Enable Function (OEB) Clock Overview Clock Input Modes Clock Input Considerations Clock Power Dissipation Clock Stabilizer (DCS) Grounding and Decoupling Analog and Digital Grounding Analog Supply Decoupling Digital Supply Decoupling Reference Decoupling CML VR EVALUATION BOARD ANALOG INPUT CONFIGURATION REFERENCE CONFIGURATION CLOCK CONFIGURATION OUTLINE DIMENSIONS ORDERING GUIDE
