link to page 13 Data SheetAD7927PIN CONFIGURATION AND FUNCTION DESCRIPTIONSSCLK 120 AGNDDIN 219 VDRIVECS 318 DOUTAD7927AGND 417 AGNDTOP VIEWAV5(Not to Scale)DD16 VIN0AV6DD15 VIN1REF7IN14 VIN2AGND 813 VIN3V9IN712 VIN4 03 V 0 10IN611 VIN5 8- 08 03 Figure 3. 20-Lead TSSOP Pin Configuration Table 4. Pin Function Descriptions Pin No.MnemonicDescription 1 SCLK Serial Clock. Logic input. SCLK provides the serial clock for accessing data from the part. This clock input is also used as the clock source for the AD7927 conversion process. 2 DIN Data In. Logic input. Data to be written to the AD7927 control register is provided on this input and is clocked into the register on the falling edge of SCLK (see the Control Register section). 3 CS Chip Select. Active low logic input. This input provides the dual function of initiating conversions on the AD7927 and framing the serial data transfer. 4, 8, 17, 20 AGND Analog Ground. Ground reference point for all analog circuitry on the AD7927. All analog input signals and any external reference signal should be referred to this AGND voltage. All AGND pins should be connected together. 5, 6 AVDD Analog Power Supply Input. The AVDD range for the AD7927 is from 2.7 V to 5.25 V. For the 0 V to 2 × REFIN range, AVDD should be from 4.75 V to 5.25 V. 7 REFIN Reference Input for the AD7927. An external reference must be applied to this input. The voltage range for the external reference is 2.5 V ±1% for specified performance. 16 to 9 VIN0 to VIN7 Analog Input 0 through Analog Input 7. Eight single-ended analog input channels that are multiplexed into the on-chip track-and-hold. The analog input channel to be converted is selected by using the address bits (ADD2 through ADD0) of the control register. ADD2 through ADD0, in conjunction with the SEQ and SHADOW bits, allow the sequencer to be programmed. The input range for all input channels can extend from 0 V to REFIN or 0 V to 2 × REFIN, as selected via the RANGE bit in the control register. Any unused input channels should be connected to AGND to avoid noise pickup. 18 DOUT Data Out. Logic output. The conversion result from the AD7927 is provided on this output as a serial data stream. The bits are clocked out on the falling edge of the SCLK input. The data stream from the AD7927 consists of two leading zeros, two address bits indicating which channel the conversion result corresponds to, followed by the 12 bits of conversion data (MSB first). The output coding may be selected as straight binary or twos complement via the CODING bit in the control register. 19 VDRIVE Logic Power Supply Input. The voltage supplied at this pin determines at what voltage the serial interface of the AD7927 operates. Rev. D | Page 7 of 28 Document Outline Features General Description Functional Block Diagram Product Highlights Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Terminology Typical Performance Characteristics Control Register Sequencer Operation Shadow Register Circuit Information Converter Operation Analog Input ADC Transfer Function Handling Bipolar Input Signals Typical Connection Diagram Analog Input Selection Digital Inputs VDRIVE The Reference Modes of Operation Normal Mode (PM1 = PM0 = 1) Full Shutdown (PM1 = 1, PM0 = 0) Auto Shutdown (PM1 = 0, PM0 = 1) Powering Up the AD7927 Power vs. Throughput Rate Serial Interface Writing Between Conversions Microprocessor Interfacing AD7927 to TMS320C541 AD7927 to ADSP-21xx AD7927 to DSP563xx Application Hints Grounding and Layout Outline Dimensions Ordering Guide Automotive Products
