AD7484ABSOLUTE MAXIMUM RATINGS TA = 25°C, unless otherwise noted. Stresses above those listed under Absolute Maximum Ratings Table 3. may cause permanent damage to the device. This is a stress ParameterRating rating only; functional operation of the device at these or any other conditions above those indicated in the operational AVDD to AGND −0.3 V to +7 V section of this specification is not implied. Exposure to absolute DVDD to DGND −0.3 V to +7 V maximum rating conditions for extended periods may affect VDRIVE to DGND −0.3 V to +7 V device reliability. Analog Input Voltage to AGND −0.3 V to AVDD + 0.3 V Digital Input Voltage to DGND −0.3 V to VDRIVE + 0.3 V ESD CAUTION REFIN to AGND −0.3 V to AVDD + 0.3 V Input Current to Any Pin Except Supply ±10 mA Pins Operating Temperature Range −40°C to +85°C Commercial Storage Temperature Range −65°C to +150°C Junction Temperature 150°C θJA Thermal Impedance 50°C/W θJC Thermal Impedance 10°C/W Lead Temperature, Soldering Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C ESD 1 kV Rev. C | Page 6 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Timing Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Circuit Description Converter Operation Analog Input ADC Transfer Function Power Saving Offset/Overrange Parallel Interface Reading Data from the AD7484 Writing to the AD7484 Driving the CONVST Pin Typical Connection Board Layout and Grounding Outline Dimensions Ordering Guide
