(VDD = 2.7 V to 3.6 V or 4.75 V to 5.25 V, REFIN(+) = 2.5 V; REFIN(–) = GND; GND = 0 V;AD7782–SPECIFICATIONS XTAL1/XTAL2 = 32.768 kHz Crystal; all specifications TMIN to TMAX unless otherwise noted.)ParameterAD7782BUnitTest Conditions ADC CHANNEL SPECIFICATION Output Update Rate 19.79 Hz nom ADC CHANNEL No Missing Codes2 24 Bits min Resolution 16 Bits p-p ±160 mV Range, RANGE = 0 18 Bits p-p ±2.56 V Range, RANGE = 1 Output Noise See Table I 2 × 1 024 . REFIN Integral Nonlinearity ±10 ppm of FSR max Typically 2 ppm FSR = Gain Offset Error ±3 µV typ AIN(+) = AIN(–) = 2.5 V Offset Error Drift vs. Temperature ±10 nV/°C typ Full-Scale Error ±10 µV typ VDD = 3 V Gain Drift vs. Temperature ±0.5 ppm/°C typ Power Supply Rejection (PSR) 100 dB typ Input Range = ± 160 mV, VIN = 1/16 V 85 dB typ Input Range = ± 2.56 V, VIN = 1 V ANALOG INPUTS Differential Input Voltage Ranges ±160 mV nom RANGE = 0 ±2.56 V nom RANGE = 1 ADC Range Matching ±2 µV typ Input Voltage = 159 mV on Both Ranges Absolute AIN Voltage Limits GND + 100 mV V min VDD – 100 mV V max Analog Input Current2 DC Input Current ±1 nA max DC Input Current Drift ±5 pA /°C typ Normal-Mode Rejection2, 3 @ 50 Hz 60 dB min 50 Hz ± 1 Hz @ 60 Hz 94 dB min 60 Hz ± 1 Hz Common-Mode Rejection Input Range = ± 160 mV, VIN = 1/16 V @ DC 105 dB min 125 dB typ, 110 dB typ when Input Range = ± 2.56 V @ 50 Hz2 100 dB min 50 Hz ± 1 Hz @ 60 Hz2 100 dB min 60 Hz ± 1 Hz REFERENCE INPUT REFIN Voltage 2.5 V nom REFIN = REFIN(+) – REFIN(–) REFIN Voltage Range2 1 V min VDD V max Absolute REFIN Voltage Limits2 GND – 30 mV V min VDD + 30 mV V max Average Reference Input Current 0.5 µA/V typ Average Reference Input Current Drift ±0.01 nA/V/°C typ Normal-Mode Rejection2, 3 @ 50 Hz 60 dB min 50 Hz ± 1 Hz @ 60 Hz 94 dB min 60 Hz ± 1 Hz Common-Mode Rejection Input Range = ± 160 mV, VIN = 1/16 V @ DC 100 dB typ @ 50 Hz 110 dB typ 50 Hz ± 1 Hz @ 60 Hz 110 dB typ 60 Hz ± 1 Hz LOGIC INPUTS All Inputs Except SCLK and XTAL12 VINL, Input Low Voltage 0.8 V max VDD = 5 V 0.4 V max VDD = 3 V VINH, Input High Voltage 2.0 V min VDD = 3 V or 5 V SCLK Only (Schmitt-Triggered Input)2 VT(+) 1.4/2 V min/V max VDD = 5 V VT(–) 0.8/1.4 V min/V max VDD = 5 V VT(+) – VT(–) 0.3/0.85 V min/V max VDD = 5 V VT(+) 0.95/2 V min/V max VDD = 3 V VT(–) 0.4/1.1 V min/V max VDD = 3 V VT(+) – VT(–) 0.3/0.85 V min/V max VDD = 3 V –2– REV. A
