AD7675–Typical Performance Characteristics1.0016000146870.75140000.50120000.25100000.008000INL – LSBCOUNTS–0.256000–0.504000–0.75200088781000000000–1.0000000163843276849152655367FF8 7FF9 7FFA 7FFB 7FFC 7FFD 7FFE 7FFF 8000 8001 8002CODECODE IN HEXA TPC 1. Integral Nonlinearity vs. Code TPC 4. Histogram of 16,384 Conversions of a DC Input at the Code Center 9000188246 8118800016700014600012500010COUNTS 400083000NUMBER OF UNITS62000410002000614000000007FFB 7FFC 7FFD 7FFE 7FFF 8000 8001 8002 8003 8004–1.0–0.8–0.6–0.4–0.20.0CODE IN HEXANEGATIVE INL – LSB TPC 2. Histogram of 16,384 Conversions of a DC Input at TPC 5. Typical Negative INL Distribution (40 Units) the Code Transition 180fS = 100 kSPS16–20fIN = 45.01kHz SNR = 94dB THD = –110dB14–40SFDR = 110dB SINAD = 93.9dB12–6010–808–100NUMBER OF UNITS6–1204AMPLITUDE – dB of Full Scale –1402–1600–18000.20.40.60.81.001020304050POSITIVE INL – LSBFREQUENCY – kHz TPC 3. Typical Positive INL Distribution (40 Units) TPC 6. FFT Plot –8– REV. A Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PulSAR Selection GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS Table I. Serial Clock Timings in Master Read after Convert ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN FUNCTION DESCRIPTIONS PIN CONFIGURATION DEFINITION OF SPECIFICATIONS INTEGRAL NONLINEARITY ERROR (INL) DIFFERENTIAL NONLINEARITY ERROR (DNL) +FULL-SCALE ERROR –FULL-SCALE ERROR BIPOLAR ZERO ERROR SPURIOUS FREE DYNAMIC RANGE (SFDR) EFFECTIVE NUMBER OF BITS (ENOB) TOTAL HARMONIC DISTORTION (THD) SIGNAL-TO-NOISE RATIO (SNR) SIGNAL-TO-(NOISE + DISTORTION) RATIO (S/[N+D]) APERTURE DELAY TRANSIENT RESPONSE Typical Performance Characteristics CIRCUIT INFORMATION CONVERTER OPERATION Transfer Functions TYPICAL CONNECTION DIAGRAM Analog Inputs Single to Differential Driver Driver Amplifier Choice Voltage Reference Input Power Supply POWER DISSIPATION CONVERSION CONTROL DIGITAL INTERFACE PARALLEL INTERFACE SERIAL INTERFACE MASTER SERIAL INTERFACE Internal Clock SLAVE SERIAL INTERFACE External Clock External Discontinuous Clock Data Read after Conversion External Clock Data Read During Conversion MICROPROCESSOR INTERFACING SPI Interface (MC68HC11) ADSP-21065L in Master Serial Interface APPLICATION HINTS Layout Evaluating the AD7675 Performance OUTLINE DIMENSIONS Revision History
