AD7492PIN CONFIGURATION AND FUNCTION DESCRIPTIONSDB9 124 DB8DB10 223 DB7(MSB) DB11 322 DB6AV421DDVDRIVEREF OUT 520AD7492DVDDVIN 619TOP VIEWDGNDAGND 7 (Not to Scale) 18 DB5CS 817 DB4RD 916 DB3CONVST 1015 DB2PS/FS 1114 DB1 3 00 BUSY 1213 DB0 (LSB) 8- 12 01 Figure 3. Pin Configuration Table 5. Pin Function Descriptions PinMnemonicFunction 1 to 3, DB11 to DB0 Data Bit 11 to Data Bit 0. Parallel digital outputs that provide the conversion result for the part. These are 13 to 18, three-state outputs that are controlled by CS and RD. The output high voltage level for these outputs is 22 to 24 determined by the VDRIVE input. 4 AVDD Analog Supply Voltage, 2.7 V to 5.25 V. This is the only supply voltage for all analog circuitry on the AD7492. The AVDD and DVDD voltages should ideally be at the same potential and must not be more than 0.3 V apart, even on a transient basis. This supply should be decoupled to AGND. 5 REF OUT Reference Out. The output voltage from this pin is 2.5 V ± 1%. 6 VIN Analog Input. Single-ended analog input channel. The input range is 0 V to REFIN. The analog input presents a high dc input impedance. 7 AGND Analog Ground. Ground reference point for all analog circuitry on the AD7492. All analog input signals should be referred to this AGND voltage. The AGND and DGND voltages should ideally be at the same potential and must not be more than 0.3 V apart, even on a transient basis. 8 CS Chip Select. Active low logic input used in conjunction with RD to access the conversion result. The conversion result is placed on the data bus following the falling edge of both CS and RD. CS and RD are both connected to the same AND gate on the input so the signals are interchangeable. CS can be hardwired permanently low. 9 RD Read Input. Logic input used in conjunction with CS to access the conversion result. The conversion result is placed on the data bus following the falling edge of both CS and RD. CS and RD are both connected to the same AND gate on the input so the signals are interchangeable. CS and RD can be hardwired permanently low, in which case the data bus is always active and the result of the new conversion is clocked out slightly before to the BUSY line going low. 10 CONVST Conversion Start Input. Logic input used to initiate conversion. The input track/hold amplifier goes from track mode to hold mode on the falling edge of CONVST and the conversion process is initiated at this point. The conversion input can be as narrow as 10 ns. If the CONVST input is kept low for the duration of conversion and is still low at the end of conversion, the part automatically enters a sleep mode. The type of sleep mode is determined by the PS/FS pin. If the part enters a sleep mode, the next rising edge of CONVST wakes up the part. Wake-up time depends on the type of sleep mode. 11 PS/FS Partial Sleep/Full Sleep Mode. This pin determines the type of sleep mode the part enters if the CONVST pin is kept low for the duration of the conversion and is still low at the end of conversion. In partial sleep mode the internal reference circuit and oscillator circuit are not powered down and draws 250 μA maximum. In full sleep mode all of the analog circuitry are powered down and the current drawn is negligible. This pin is hardwired either high (DVDD) or low (GND). 12 BUSY BUSY Output. Logic output indicating the status of the conversion process. The BUSY signal goes high after the falling edge of CONVST and stays high for the duration of the conversion. Once the conversion is complete and the conversion result is in the output register, the BUSY line returns low. The track/hold returns to track mode just prior to the falling edge of BUSY and the acquisition time for the part begins when BUSY goes low. If the CONVST input is still low when BUSY goes low, the part automatically enters its sleep mode on the falling edge of BUSY. 19 DGND Digital Ground. This is the ground reference point for all digital circuitry on the AD7492. The DGND and AGND voltages should ideally be at the same potential and must not be more than 0.3 V apart, even on a transient basis. Rev. A | Page 8 of 24 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AD7492-5 AD7492/AD7492-4 TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PEFORMANCE CHARACTERISTICS TERMINOLOGY CIRCUIT DESCRIPTION CONVERTER OPERATION TYPICAL CONNECTION DIAGRAM ADC TRANSFER FUNCTION AC ACQUISITION TIME DC ACQUISITION TIME ANALOG INPUT PARALLEL INTERFACE OPERATING MODES POWER-UP GROUNDING AND LAYOUT POWER SUPPLIES MICROPROCESSOR INTERFACING OUTLINE DIMENSIONS ORDERING GUIDE
