Datasheet AD9214 (Analog Devices) - 3
Description10-Bit, 65/80/105 MSPS, +3.3V A/D Converter
Pages / Page21 / 3 — AD9214–SPECIFICATIONS. (AV. DC SPECIFICATIONS. DD = 3 V, DrVDD = 3 V; …
RevisionD
File Format / SizePDF / 486 Kb
AD9214–SPECIFICATIONS. (AV. DC SPECIFICATIONS. DD = 3 V, DrVDD = 3 V; TMIN = –40. C, TMAX = +85
AD9214–SPECIFICATIONS (AV DC SPECIFICATIONS DD = 3 V, DrVDD = 3 V; TMIN = –40 C, TMAX = +85
C, TMAX = +85
C; external 1.25 V voltage reference and rated encode frequency used, unless otherwise noted.) Test AD9214-65 AD9214-80 AD9214-105 Parameter Temp Level Min Typ Max Min Typ Max Min Typ Max Unit
RESOLUTION 10 10 10 Bits ACCURACY No Missing Codes 25°C VI Guaranteed Guaranteed Guaranteed Full VI Guaranteed Guaranteed Offset Error Full VI –18 0 +18 –18 0 +18 –18 0 +18 LSB Gain Error1 25°C I –2 +8 –2 +8 –2 +8 % FS Differential Nonlinearity2 25°C I –1.0 ±0.5 +1.0 –1.0 ±0.5 +1.2 –1.0 ±0.8 +1.5 LSB (DNL) Full V –1.0 +1.2 –1.0 +1.4 +1.7 LSB Integral Nonlinearity2 25°C I –1.35 ±0.75 +1.35 –1.5 ±0.75 +1.5 –2.2 ±1.5 +2.2 LSB (INL) Full V –1.9 +1.9 –1.8 +1.8 –2.5 +2.5 LSB TEMPERATURE DRIFT Offset Error Full V 16 16 16 ppm/°C Gain Error1 Full V 150 150 150 ppm/°C Reference Voltage Full V 80 80 80 ppm/°C REFERENCE (REF) Internal Reference Voltage 25°C VI 1.18 1.23 1.28 1.18 1.23 1.28 1.18 1.23 1.28 V Output Current3 Full V 200 200 200 µA Input Current4 Full V 123 123 123 µA Input Resistance Full V 10 10 10 kΩ ANALOG INPUTS (AIN, AIN) Differential Input Range Full V 1 or 2 1 or 2 1 or 2 V p-p Common-Mode Voltage Full V AVDD/3 AVDD/3 AVDD/3 V Differential Input Resistance5 Full V 20 20 20 kΩ Differential Input Capacitance Full V 5 5 5 pF POWER SUPPLY Supply Voltages AVDD Full IV 2.7 3.6 2.7 3.6 2.7 3.6 V DrVDD Full IV 2.7 3.6 2.7 3.6 2.7 3.6 V Supply Current IAVDD (AVDD = 3.0 V)6 Full VI 64 75 90 105 95 110 mA Power-Down Current7 IAVDD (AVDD = 3.0 V) Full VI 10 15 10 15 10 15 mA Power Consumption8 Full VI 190 220 250 300 285 325 mW PSRR 25°C I ±0.5 ±1 ±1 LSB/V Full V ±2 ±2 ±2 mV/V NOTES 1Gain error and gain temperature coefficient are based on the ADC only (with a fixed 1.25 V external reference). 2Measured with 1 V AIN range for AD9214-80 and AD9214-105. Measured with 2 V AIN range for AD9214-65. 3REFSENSE externally connected to AGND, REF is configured as an output for the internal reference voltage. 4REFSENSE externally connected to AVDD, REF is configured as an input for an external reference voltage. 510 kΩ to AVDD/3 on each input. 6IAVDD is measured with an analog input of 10.3 MHz, 0.5 dBFS, sine wave, rated encode rate, and PWRDN = 0. See Typical Performance Characteristics and Applications section for IDrVDD. 7Power-down supply currents measured with PWRDN = 1; rated encode rate, A IN = full-scale dc input. 8Power consumption measured with AIN = full-scale dc input. Specifications subject to change without notice. –2– REV. D
