Datasheet AD9214 (Analog Devices) - 6
Description10-Bit, 65/80/105 MSPS, +3.3V A/D Converter
Pages / Page21 / 6 — AD9214. ABSOLUTE MAXIMUM RATINGS1. EXPLANATION OF TEST LEVELS. ORDERING …
RevisionD
File Format / SizePDF / 486 Kb
AD9214. ABSOLUTE MAXIMUM RATINGS1. EXPLANATION OF TEST LEVELS. ORDERING GUIDE. Model. Temperature Range. Package Description
AD9214 ABSOLUTE MAXIMUM RATINGS1 EXPLANATION OF TEST LEVELS ORDERING GUIDE Model Temperature Range Package Description
Electrical I 100% production tested. AVDD Voltage . 4 V max II 100% production tested at 25°C and guaranteed by design DrVDD Voltage . 4 V max and characterization at specified temperatures. Analog Input Voltage . –0.5 V to AVDD + 0.5 V Analog Input Current . 0.4 mA III Sample Tested Only Digital Input Voltage . –0.5 V to AVDD + 0.5 V IV Parameter is guaranteed by design and characterization Digital Output Current . 20 mA max testing. REF Input Voltage . –0.5 V to AVDD + 0.5 V V Parameter is a typical value only. Environmental2 Operating Temperature Range (Ambient) VI 100% production tested at 25°C and guaranteed by design . –40°C to +125°C and characterization for industrial temperature range. Maximum Junction Temperature . 150°C Lead Temperature (Soldering, 10 sec) . 150°C Storage Temperature Range (Ambient) . –65°C to +150°C NOTES 1Absolute maximum ratings are limiting values to be applied individually, and beyond which the serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to absolute maximum rating condi- tions for an extended period of time may affect device reliability. 2Typical thermal impedances (package = 28 SSOP); θJA = 49°C/W. These measurements were taken on a 6-layer board in still air with a solid ground plane.
ORDERING GUIDE Model Temperature Range Package Description Package Option
AD9214BRS-65 –40°C to +85°C (Ambient) 28-Lead Shrink Small Outline Package RS-28 AD9214BRS-80 –40°C to +85°C (Ambient) 28-Lead Shrink Small Outline Package RS-28 AD9214BRS-105 –40°C to +85°C (Ambient) 28-Lead Shrink Small Outline Package RS-28 AD9214-65PCB 25°C Evaluation Board with AD9214-65 AD9214-105PCB 25°C Evaluation Board with AD9214-105
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although
WARNING!
the AD9214 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD precautions are
ESD SENSITIVE DEVICE
recommended to avoid performance degradation or loss of functionality. REV. D –5–
