Datasheet AD10200 (Analog Devices) - 3
DescriptionDual Channel, 12-Bit, 105 MSPS IF Sampling A/D Converter With Analog Input Signal Conditioning
Pages / Page20 / 3 — AD10200–SPECIFICATIONS1 (VDD = 3.3 V, VCC = 5.0 V; ENCODE = 105 MSPS, …
AD10200–SPECIFICATIONS1 (VDD = 3.3 V, VCC = 5.0 V; ENCODE = 105 MSPS, unless otherwise noted). Test. MIL. Parameter. Temp. Level
AD10200–SPECIFICATIONS1 (VDD = 3.3 V, VCC = 5.0 V; ENCODE = 105 MSPS, unless otherwise noted) Test MIL Parameter Temp Level
AD10200–SPECIFICATIONS1 (VDD = 3.3 V, VCC = 5.0 V; ENCODE = 105 MSPS, unless otherwise noted) Test MIL Parameter Temp Level Subgroup Min Typ Max Unit
RESOLUTION 12 Bits DC ACCURACY Differential Nonlinearity Full IV 12 –0.99 ±0.5 +0.99 LSB Integral Nonlinearity Full IV 12 –3 ±0.75 +3 LSB No Missing Codes Full I 1, 2, 3 Guaranteed Gain Error2 Full I 1, 2, 3 –9 ±1 +9 % FS Output Offset Full I 1, 2, 3 –12 +12 LSB ANALOG INPUT Input Voltage Range 25°C V 2.048 V p-p Input Impedance 25°C V 50 Ω Input VSWR3 Full IV 12 1.1:1 1.25:1 Ratio Analog Input Bandwidth, High Full IV 12 200 250 MHz Analog Input Bandwidth, Low Full IV 12 1 MHz ANALOG REFERENCE Output Voltage Full I 1, 2, 3 2.4 2.5 2.6 V Load Current 25°C V 5 mA Tempco Full V 50 ppm/°C SWITCHING PERFORMANCE Maximum Conversion Rate Full I 4, 5, 6 105 MSPS Minimum Conversion Rate Full IV 12 10 MSPS Duty Cycle Full IV 12 45 50 55 % Aperture Delay (tA) 25°C V 1.0 ns Aperture Uncertainty (Jitter) 25°C V 0.25 ps rms Output Valid Time (tV)4 Full IV 12 3.0 5.3 ns Output Propagation Delay (PD)4 Full IV 12 4.5 5.5 8.0 ns Output Rise Time (tR) 25°C V 12 3.5 ns Output Fall Time (tF) 25°C V 12 3.3 ns DIGITAL INPUTS Encode Input Common Mode Full IV 12 1.2 1.6 2.0 V Differential Input (Enc, Enc) Full IV 12 0.4 5.0 V Logic “1” Voltage Full IV 12 2.0 V Logic “0” Voltage Full IV 12 0.8 V Input Resistance Full IV 12 3 5 8 kΩ Input Capacitance 25°C V 4.5 pF DIGITAL OUTPUTS Logic “1” Voltage4 Full VI 1, 2, 3 3.1 3.3 V Logic “0” Voltage4 Full VI 1, 2, 3 0 0.2 V Output Coding Two’s Complement POWER SUPPLY5 Power Dissipation6 Full I 1, 2, 3 1800 2200 mW Power Supply Rejection Ratio Full IV 12 ±0.5 ±5 mV/V I (DVDD) Current Full I 1, 2, 3 25 40 mA I (AVCC) Current Full I 1, 2, 3 340 410 mA DYNAMIC PERFORMANCE Signal-to-Noise Ratio (SNR)7 (Without Harmonics) fIN = 10 MHz 25°C V 67 dBFS Full V 66 dBFS fIN = 41 MHz 25°C I 4 64 66.5 dBFS Full II 5, 6 62 65 dBFS fIN = 71 MHz 25°C I 4 62.5 66.4 dBFS Full II 5, 6 61.5 64 dBFS fIN = 121 MHz 25°C I 4 61 65 dBFS Full II 5, 6 61 64 dBFS –2– REV. B
