Datasheet AD9226 (Analog Devices) - 5
Description12-Bit, 65 MSPS Analog-to-Digital Converter
Pages / Page29 / 5 — AD9226–SPECIFICATIONS
AD9226–SPECIFICATIONS AC SPECIFICATIONS (AVDD = 5 V, DRVDD = 3 V, fSAMPLE = 65 MSPS, VREF = 2.0 V, TMIN to TMAX, Differential Input unless otherwise noted.) Parameter Temp Test Level Min Typ Max Unit
SIGNAL-TO-NOISE RATIO fIN = 2.5 MHz Full V 68.9 dBc 25°C I 68 dBc fIN = 15 MHz Full V 68.4 dBc 25°C I 67.4 dBc fIN = 31 MHz Full V 68 dBc fIN = 60 MHz Full V 68 dBc fIN = 200 MHz1 Full V 65 dBc SIGNAL-TO-NOISE RATIO AND DISTORTION fIN = 2.5 MHz Full V 68.8 dBc 25°C I 67.9 dBc fIN = 15 MHz Full V 68.3 dBc 25°C I 67.3 dBc fIN = 31 MHz Full V 67 dBc fIN = 60 MHz Full V 67 dBc fIN = 200 MHz1 Full V 60 dBc TOTAL HARMONIC DISTORTION fIN = 2.5 MHz Full V –84 dBc 25°C I –77.0 dBc fIN = 15 MHz Full V –82.3 dBc 25°C I –76.0 dBc fIN = 31 MHz Full V –68 dBc fIN = 60 MHz Full V –68 dBc fIN = 200 MHz1 Full V –61 dBc SECOND AND THIRD HARMONIC DISTORTION fIN = 2.5 MHz Full V –86.5 dBc 25°C I –78 dBc fIN = 15 MHz Full V –86.7 dBc 25°C I –76 dBc fIN = 31 MHz Full V –83 dBc fIN = 60 MHz Full V –82 dBc fIN = 200 MHz1 Full V –75 dBc SPURIOUS FREE DYNAMIC RANGE fIN = 2.5 MHz Full V 86.4 dBc 25°C I 78 dBc fIN = 15 MHz Full V 85.5 dBc 25°C I 76 dBc fIN = 31 MHz Full V 82 dBc fIN = 60 MHz Full V 81 dBc fIN = 200 MHz1 Full V 60 dBc ANALOG INPUT BANDWIDTH 25°C V 750 MHz NOTES 11.0 V Reference and Input Span Specifications subject to change without notice. –4– REV. B
