Datasheet AD9288 (Analog Devices) - 8
Description8-Bit, 40/80/100 MSPS Dual A/D Converter
Pages / Page25 / 8 — AD9288. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. ESD CAUTION
RevisionC
File Format / SizePDF / 643 Kb
AD9288 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
AD9288 ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating
VD, VDD 4 V Stresses above those listed under Absolute Maximum Ratings Analog Inputs –0.5 V to VD + 0.5 V may cause permanent damage to the device. This is a stress Digital Inputs –0.5 V to VDD + 0.5 V rating only; functional operation of the device at these or any VREF IN –0.5 V to VD + 0.5 V other conditions outside of those indicated in the operation Digital Output Current 20 mA sections of this specification is not implied. Exposure to Operating Temperature –55°C to +125°C absolute maximum ratings for extended periods may affect Storage Temperature –65°C to +150°C device reliability. Maximum Junction Temperature 150°C Maximum Case Temperature 150°C Thermal Impedance θja 57°C/W
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. C | Page 7 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS EXPLANATION OF TEST LEVELS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION USING THE AD9288 ENCODE INPUT DIGITAL OUTPUTS ANALOG INPUT VOLTAGE REFERENCE TIMING USER-SELECTABLE OPTIONS AD9218/AD9288 CUSTOMER PCB BOM EVALUATION BOARD POWER CONNECTOR ANALOG INPUTS VOLTAGE REFERENCE CLOCKING DATA OUTPUTS DATA FORMAT/GAIN TIMING TROUBLESHOOTING OUTLINE DIMENSIONS ORDERING GUIDE
