Datasheet AD7894 (Analog Devices) - 10
DescriptionTrue Bipolar Input, 5 V Single Supply, 14-Bit, Serial 4.5 µs ADC in 8-Pin Package
Pages / Page13 / 10 — AD7894. P1.2 OR INT1. BUSY. 8X51/L51. P3.0. SDATA. P3.1. SCLK. AD7894 to …
File Format / SizePDF / 165 Kb
AD7894. P1.2 OR INT1. BUSY. 8X51/L51. P3.0. SDATA. P3.1. SCLK. AD7894 to 68HC11/L11 Interface. MICROPROCESSOR/MICROCONTROLLER INTERFACE
AD7894 P1.2 OR INT1 BUSY 8X51/L51 P3.0 SDATA P3.1 SCLK AD7894 to 68HC11/L11 Interface MICROPROCESSOR/MICROCONTROLLER INTERFACE
AD7894
CONVST, the AD7894 will continue to operate correctly The serial clock rate from the 8X51/L51 is limited to signifi- with the output shift register being reset on the falling edge of cantly less than the allowable input serial clock frequency with CONVST. However, the SCLK line must be low when CONVST which the AD7894 can operate. As a result, the time to read goes low in order to reset the output shift register correctly. data from the part will actually be longer than the conversion The serial clock input does not have to be continuous during the time of the part. This means that the AD7894 cannot run at its serial read operation. The 16 bits of data (two leading zeros and maximum throughput rate when used with the 8X51/L51. 14-bit conversion result) can be read from the AD7894 in a number of bytes. The AD7894 counts the serial clock edges to know which bit
P1.2 OR INT1 BUSY
from the output register should be placed on the SDATA out-
AD7894 8X51/L51
put. To ensure that the part does not lose synchronization, the
P3.0 SDATA
serial clock counter is reset on the falling edge of the CONVST input provided the SCLK line is low. The user should ensure that the SCLK line remains low until the end of the conversion.
P3.1 SCLK
When the conversion is complete, BUSY goes low, the output register will be loaded with the new conversion result and can be Figure 6. AD7894 to 8X51/L51 Interface read from with 16 clock cycles of SCLK.
An interface circuit between the AD7894 and the 68HC11/L11 The AD7894 provides a two-wire serial interface that can be microcontroller is shown in Figure 7. For the interface shown, used for connection to the serial ports of DSP processors and the 68L11 SPI port is used and the 68L11 is configured in its microcontrollers. Figures 6 through 9 show the AD7894 single-chip mode. The 68L11 is configured in the master mode interfaced to a number of different microcontrollers and DSP with its CPOL bit set to a logic zero and its CPHA bit set to a processors. The AD7894 accepts an external serial clock and logic one. As with the previous interface, the diagram shows the as a result, in all interfaces shown here, the processor/controller simplest form of the interface where the AD7894 is the only part is configured as the master, providing the serial clock, with connected to the serial port of the 68L11 and therefore no de- the AD7894 being the slave in the system. The BUSY signal coding of the serial read operations is required. need not be used for a two-wire interface if the read can be Once again, to select the AD7894 in systems where more than timed to occur 5 µs after the start of conversion (assuming one device is connected to the 68HC11’s serial port, a port bit, Mode 1 operation). configured as an output from one of the 68HC11’s parallel
ports, can be used to gate on or off the serial clock to the AD7894. Figure 6 shows an interface between the AD7894 and the A simple AND function on this port bit and the serial clock 8X51/L51 microcontroller. The 8X51/L51 is configured for its from the 68L11 will provide this function. The port bit should Mode 0 serial interface mode. The diagram shows the simplest be high to select the AD7894 and low when it is not selected. form of the interface where the AD7894 is the only part con- The end of conversion is monitored by using the BUSY signal, nected to the serial port of the 8X51/L51 and, therefore, no which is shown in the interface diagram of Figure 7. With the decoding of the serial read operations is required. BUSY line from the AD7894 connected to the Port PC2 of the To select the AD7894 in systems where more than one device is 68HC11/L11 the BUSY line can be polled by the 68HC11/L11. connected to the 8X51/L51’s serial port, a port bit, configured The BUSY line can be connected to the IRQ line of the 68HC11/ as an output from one of the 8X51/L51’s parallel ports, can be L11 if an interrupt driven system is preferred. These two op- used to gate on or off the serial clock to the AD7894. A simple tions are shown in the diagram. AND function on this port bit and the serial clock from the The serial clock rate from the 68HC11/L11 is limited to signifi- 8X51/L51 will provide this function. The port bit should be cantly less than the allowable input serial clock frequency with high to select the AD7894 and low when it is not selected. which the AD7894 can operate. As a result, the time to read The end of conversion can be monitored by using the BUSY data from the part will be longer than the conversion time of the signal, which is shown in the interface diagram of Figure 6. part. This means that the AD7894 cannot run at its maximum With the BUSY line from the AD7894 connected to the Port throughput rate when used with the 68HC11/L11. P1.2 of the 8X51/L51 the BUSY line can be polled by the 8X51/L51. The BUSY line can be connected to the INT1 line of the 8X51/L51 if an interrupt driven system is preferred.
PC2 OR IRQ BUSY
These two options are shown on the diagram.
AD7894 68HC11/L11
Note also that the AD7894 outputs the MSB first during a read
SCK SCLK
operation while the 8X51/L51 expects the LSB first. Therefore, the data that is read into the serial buffer needs to be rearranged before the correct data format from the AD7894 appears in the
MISO SDATA
accumulator. Figure 7. AD7894 to 68HC11/L11 Interface REV. 0 –9–
