Datasheet AD6640 (Analog Devices) - 3
DescriptionMulti-Channel, Multi-Mode Receiver Chipset
Pages / Page25 / 3 — AD6640–SPECIFICATIONS DC SPECIFICATIONS (AVCC = 5 V, DVCC = 3.3 V; TMIN = …
AD6640–SPECIFICATIONS DC SPECIFICATIONS (AVCC = 5 V, DVCC = 3.3 V; TMIN = –40. C, TMAX = +85. C, unless otherwise noted.)
AD6640–SPECIFICATIONS DC SPECIFICATIONS (AVCC = 5 V, DVCC = 3.3 V; TMIN = –40 C, TMAX = +85 C, unless otherwise noted.)
C, TMAX = +85
C, unless otherwise noted.) Test AD6640AST Parameter Temp Level Min Typ Max Unit
RESOLUTION 12 Bits ACCURACY No Missing Codes +25°C I GUARANTEED Offset Error Full VI –10 +3.5 +10 mV Gain Error Full VI –10 +4.0 +10 % FS Differential Nonlinearity (DNL)1 +25°C I –1.0 ±0.5 +1.5 LSB Integral Nonlinearity (INL)1 Full V ±1.25 LSB TEMPERATURE DRIFT Offset Error Full V 50 ppm/°C Gain Error Full V 100 ppm/°C POWER SUPPLY REJECTION RATIO (PSRR) Full V ±0.5 mV/V REFERENCE OUT (VREF)2 Full V 2.4 V ANALOG INPUTS (AIN, AIN)3 Analog Input Common-Mode Range4 Full V VREF ± 0.05 V Differential Input Voltage Range Full V 2.0 V p-p Differential Input Resistance Full IV 0.7 0.9 1.1 kΩ Differential Input Capacitance +25°C V 1.5 pF POWER SUPPLY Supply Voltage AVCC Full VI 4.75 5.0 5.25 V DVCC Full VI 3.0 3.3 5.25 V Supply Current IAVCC (AVCC = 5.0 V) Full VI 135 160 mA IDVCC (DVCC = 3.3 V) Full VI 10 20 mA POWER CONSUMPTION Full VI 710 865 mW NOTES 1 ENCODE = 20 MSPS 2 If VREF is used to provide a dc offset to other circuits, it should first be buffered. 3The AD6640 is designed to be driven differentially. Both AIN and AIN should be driven at levels VREF ± 0.5 V. The input signals should be 180 degrees out of phase to produce a 2 V p-p differential input signal. See Driving the Analog Inputs section for more details. 4 Analog input common-mode range specifies the offset range the analog inputs can tolerate in dc-coupled applications (see Figure 17 for more detail). Specifications subject to change without notice.
DIGITAL SPECIFICATIONS (AVCC = 5 V, DVCC = 3.3 V; TMIN = –40
C, TMAX = +85
LOGIC INPUTS (ENCODE, ENCODE)1 ENCODE Input Common-Mode Range2 Full IV 0.2 2.2 V Differential Input Voltage Full IV 0.4 V p-p Single-Ended ENCODE 10 V p-p Logic Compatibility3 TTL/CMOS Logic “1” Voltage Full VI 2.0 5.0 V Logic “0” Voltage Full VI 0 0.8 V Logic “1” Current (VINH = 5 V) Full VI +500 +650 +800 µA Logic “0” Current (VINL = 0 V) Full VI –400 –320 –200 µA Input Capacitance +25°C V 2.5 pF LOGIC OUTPUTS (D11–D0)4 Logic Compatibility CMOS Logic “1” Voltage (DVCC = 3.3 V) Full VI 2.8 DVCC – 0.2 V Logic “0” Voltage (DVCC = 3.3 V) Full VI 0.2 0.5 V Logic “1” Voltage (DVCC = 5.0 V) Full IV 4.5 DVCC – 0.3 V Logic “0” Voltage (DVCC = 5.0 V) Full IV 0.35 0.5 V Output Coding Twos Complement NOTES 1Best dynamic performance is obtained by driving ENCODE and ENCODE differentially. See Encoding the AD6640 section for more details. Performance versus ENCODE/ENCODE power is shown in TPC 12. 2For dc-coupled applications, the ENCODE input common-mode range specifies the common-mode range the ENCODE inputs can tolerate when driven differentially by the minimum differential input voltage of 0.4 V p-p. For differential input voltage swings greater than 0.4 V p-p, the common-mode range will change. The minimum value ensures that the input voltage on either encode pin does not go below 0 V. The maximum value ensures that the input voltage on either ENCODE pin does not go below 2.0 V or above AVCC (e.g., for a differential input swing of 0.8 V, the min and max common-mode specs become 0.4 V and 2.4 V, respectively). 3ENCODE or ENCODE may be driven alone if desired, but performance will likely be degraded. Logic compatibility specifications are provided to show that TTL or CMOS clock sources will work. When driving only one ENCODE input, bypass the complementary input to GND with 0.01 µF. 4Digital output load is one LCX gate. Specifications subject to change without notice. –2– REV. A Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS DC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS AC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ORDERING GUIDE PIN FUNCTION DESCRIPTIONS PIN CONFIGURATION DEFINITION OF SPECIFICATIONS Analog Bandwidth (Small Signal) Aperture Delay Aperture Uncertainty (Jitter) Differential Nonlinearity Encode Pulsewidth/Duty Cycle Integral Nonlinearity Minimum Conversion Rate Maximum Conversion Rate Output Propagation Delay Power Supply Rejection Ratio Signal-to-Noise-and-Distortion (SINAD) Signal-to-Noise Ratio (SNR) Spurious-Free Dynamic Range (SFDR) Two-Tone Intermodulation Distortion Rejection Two-Tone SFDR Worst Harmonic Equivalent Circuits Typical Performance Characteristics THEORY OF OPERATION APPLYING THE AD6640 Encoding the AD6640 Driving the Analog Input Power Supplies Output Loading Layout Information Evaluation Boards DIGITAL WIDEBAND RECEIVERS Introduction System Description System Requirements Noise Floor and SNR Processing Gain Overcoming Static Nonlinearities with Dither Receiver Example IF Sampling Using the AD6640 as a Mix-Down Stage RECEIVE CHAIN FOR A PHASED-ARRAY CELLULAR BASE STATION OUTLINE DIMENSIONS Revision History
