Datasheet AD9200 (Analog Devices) - 3
Description | 10-Bit, 20 MSPS, 80 mW CMOS A/D Converter |
Pages / Page | 25 / 3 — AD9200–SPECIFICATIONS (AVDD = +3 V, DRVDD = +3 V, FS = 20 MHz (50% Duty … |
Revision | E |
File Format / Size | PDF / 378 Kb |
AD9200–SPECIFICATIONS (AVDD = +3 V, DRVDD = +3 V, FS = 20 MHz (50% Duty Cycle), MODE = AVDD, 2 V Input
AD9200–SPECIFICATIONS (AVDD = +3 V, DRVDD = +3 V, FS = 20 MHz (50% Duty Cycle), MODE = AVDD, 2 V Input Span from 0.5 V to 2.5 V, External Reference, TMIN to TMAX unless otherwise noted) Parameter Symbol Min Typ Max Units Condition
RESOLUTION 10 Bits CONVERSION RATE FS 20 MHz DC ACCURACY Differential Nonlinearity DNL ±0.5 ±1 LSB REFTS = 2.5 V, REFBS = 0.5 V Integral Nonlinearity INL ±0.75 ±2 LSB Offset Error EZS 0.4 1.2 % FSR Gain Error EFS 1.4 3.5 % FSR REFERENCE VOLTAGES Top Reference Voltage REFTS 1 AVDD V Bottom Reference Voltage REFBS GND AVDD – 1 V Differential Reference Voltage 2 V p-p Reference Input Resistance1 10 kΩ REFTS, REFBS: MODE = AVDD 4.2 kΩ Between REFTF and REFBF: MODE = AVSS ANALOG INPUT Input Voltage Range AIN REFBS REFTS V REFBS Min = GND: REFTS Max = AVDD Input Capacitance CIN 1 pF Switched Aperture Delay tAP 4 ns Aperture Uncertainty (Jitter) tAJ 2 ps Input Bandwidth (–3 dB) BW Full Power (0 dB) 300 MHz DC Leakage Current 23 µA Input = ± FS INTERNAL REFERENCE Output Voltage (1 V Mode) VREF 1 V REFSENSE = VREF Output Voltage Tolerance (1 V Mode) ±10 ±25 mV Output Voltage (2 V Mode) VREF 2 V REFSENSE = GND Load Regulation (1 V Mode) 0.5 2 mV 1 mA Load Current POWER SUPPLY Operating Voltage AVDD 2.7 3 5.5 V DRVDD 2.7 3 5.5 V Supply Current IAVDD 26.6 33.3 mA AVDD = 3 V, MODE = AVSS Power Consumption PD 80 100 mW AVDD = DRVDD = 3 V, MODE = AVSS Power-Down 4 mW STBY = AVDD, MODE and CLOCK = AVSS Gain Error Power Supply Rejection PSRR 1 % FS DYNAMIC PERFORMANCE (AIN = 0.5 dBFS) Signal-to-Noise and Distortion SINAD f = 3.58 MHz 54.5 57 dB f = 10 MHz 54 dB Effective Bits f = 3.58 MHz 9.1 Bits f = 10 MHz 8.6 Bits Signal-to-Noise SNR f = 3.58 MHz 55 57 dB f = 10 MHz 56 dB Total Harmonic Distortion THD f = 3.58 MHz –59 –66 dB f = 10 MHz –58 dB Spurious Free Dynamic Range SFDR f = 3.58 MHz –61 –69 dB f = 10 MHz –61 dB Two-Tone Intermodulation Distortion IMD 68 dB f = 44.49 MHz and 45.52 MHz Differential Phase DP 0.1 Degree NTSC 40 IRE Mod Ramp Differential Gain DG 0.05 % –2– REV. E
