Datasheet AD9059 (Analog Devices)
DescriptionDual 8-Bit, 60 MSPS A/D Converter
Pages / Page13 / 1 — Dual 8-Bit, 60 MSPS A/D Converter. AD9059. FEATURES. FUNCTIONAL BLOCK …
RevisionA
File Format / SizePDF / 253 Kb
Dual 8-Bit, 60 MSPS A/D Converter. AD9059. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet AD9059 Analog Devices, Revision: A
Dual 8-Bit, 60 MSPS A/D Converter AD9059 FEATURES FUNCTIONAL BLOCK DIAGRAM Dual 8-Bit ADCs on a Single Chip Low Power: 400 mW Typical VD PWRDN VDD On-Chip 2.5 V Reference and Track-and-Hold AD9059 1 V p-p Analog Input Range Single 5 V Supply Operation 8 AINA T/H ADCA D7A–D0A 5 V or 3 V Logic Interface 120 MHz Analog Bandwidth VREF Power-Down Mode: <12 mW ENCODE 2.5V APPLICATIONS 8 Digital Communications (QAM Demodulators) AINB T/H ADCB D7B–D0B RGB and YC/Composite Video Processing Digital Data Storage Read Channels GND Medical Imaging Digital Instrumentation PIN CONFIGURATION PRODUCT DESCRIPTION AINA 1 28 AINB
The AD9059 is a dual 8-bit monolithic analog-to-digital converter
VREF 2 27 GND
optimized for low cost, low power, small size, and ease of use.
PWRDN 3 26 ENCODE
With a 60 MSPS encode rate capability and full-power analog
V 4 25 V D D
bandwidth of 120 MHz typical, the component is ideal for
GND 5 24 GND
applications requiring multiple ADCs with excellent dynamic
AD9059 V 6 23 V DD DD
performance.
TOP VIEW D7A (MSB) 7 (Not to Scale) 22 D7B (MSB)
To minimize system cost and power dissipation, the AD9059
D6A 8 21 D6B
includes an internal 2.5 V reference and dual track-and-hold
D5A 9 20 D5B
circuits. The ADC requires only a 5 V power supply and an
D4A 10 19 D4B
encode clock. No external reference or driver components are
D3A 11 18 D3B
required for many applications.
D2A 12 17 D2B
The AD9059’s single encode input is TTL/CMOS compatible
D1A 13 16 D1B D0A (LSB)
and simultaneously controls both internal ADC channels. The
14 15 D0B (LSB)
parallel 8-bit digital outputs can be operated from 5 V or 3 V supplies. A power-down function may be exercised to bring total consumption to <12 mW when ADC data is not required for lengthy periods of time. In power-down mode, the digital outputs are driven to a high impedance state. Fabricated on an advanced BiCMOS process, the AD9059 is available in a space-saving 28-lead shrink small outline package (28-lead SSOP) and is specified over the industrial temperature range (–40°C to +85°C). Customers desiring single-channel digitization may consider the AD9057, a single 8-bit, 60 MSPS monolithic based on the AD9059 ADC core. The AD9057 is available in a 20-lead shrink small outline package (20-lead SSOP) and is specified over the industrial temperature range. REV. A Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise
under any patent or patent rights of Analog Devices. Trademarks and
Tel: 781/329-4700 www.analog.com
registered trademarks are the property of their respective companies.
Fax: 781/326-8703 © 2003 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PIN CONFIGURATION SPECIFICATIONS EXPLANATION OF TEST LEVELS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS Typical Performance Characteristics THEORY OF OPERATION USING THE AD9059 Analog Inputs Voltage Reference Digital Logic (5 V/3 V Systems) Timing Power Dissipation Applications Evaluation Board OUTLINE DIMENSIONS Revision History
