Datasheet AD10242 (Analog Devices) - 2
DescriptionDual Channel, 12-Bit, 40 MSPS MCM A/D Converter with DC-Coupled Analog Input Signal Conditioning (AD9042 Core ADC)
Pages / Page16 / 2 — AD10242* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionD
File Format / SizePDF / 453 Kb
AD10242* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
AD10242* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
View a parametric search of comparable parts.
Technical Articles
• Class T Satellite Products
EVALUATION KITS
• Correlating High-Speed ADC Performance to Multicarrier • AD10242 Evaluation Board 3G Requirements • DNL and Some of its Effects on Converter Performance
DOCUMENTATION
• MS-2210: Designing Power Supplies for High Speed ADC
Application Notes
• Multi-Channel Analog-to-Digital Converter Module • AN-297: Test Video A/D Converters Under Dynamic Integration Conditions
Data Sheet DESIGN RESOURCES
• AD10242 Military Data Sheet • AD10242 Material Declaration • AD10242: Dual, 12-Bit, 40 MSPS MCM A/D Converter with • PCN-PDN Information Analog Input Signal Conditioning Data Sheet • Quality And Reliability • Symbols and Footprints
SOFTWARE AND SYSTEMS REQUIREMENTS
• Military Part Cross-Reference Guide
DISCUSSIONS
• Military Products by Function View all AD10242 EngineerZone Discussions. • Military Products by GENERIC Part Number • SMD to Generic Cross Reference
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS1 EXPLANATION OF TEST LEVELS PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS DEFINITION OF SPECIFICATIONS Analog Bandwidth Aperture Delay Aperture Uncertainty (Jitter) Differential Nonlinearity Encode Pulsewidth/Duty Cycle Harmonic Distortion Integral Nonlinearity Minimum Conversion Rate Maximum Conversion Rate Output Propagation Delay Overvoltage Recovery Time Power Supply Rejection Ratio Signal-to-Noise and Distortion (SINAD) Signal-to-Noise Ratio (SNR, without Harmonics) Spurious-Free Dynamic Range (SFDR) Transient Response Two-Tone Intermodulation Distortion Rejection Two-Tone SFDR EQUIVALENT CIRCUITS Typical Performance Characteristics THEORY OF OPERATION APPLYING THE AD10242 Encoding the AD10242 Performance Improvements USING THE FLEXIBLE INPUT GROUNDING AND DECOUPLING Analog and Digital Grounding LAYOUT INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS Ordering Guide Revision History
