Datasheet AD7859, AD7859L (Analog Devices)
Description | 3 V to 5 V Single Supply, 200 kSPS 8-Channel, 12-Bit, Parallel Sampling ADCs |
Pages / Page | 29 / 1 — 3 V to 5 V Single Supply, 200 kSPS. 8-Channel, 12-Bit Sampling ADCs. … |
Revision | A |
File Format / Size | PDF / 456 Kb |
3 V to 5 V Single Supply, 200 kSPS. 8-Channel, 12-Bit Sampling ADCs. AD7859/AD7859L. FEATURES. FUNCTIONAL BLOCK DIAGRAM
![Datasheet AD7859, AD7859L Analog Devices, Revision: A](https://www.rlocman.ru/datasheet/img.php?di=125673)
a
8-Channel, 12-Bit Sampling ADCs AD7859/AD7859L FEATURES FUNCTIONAL BLOCK DIAGRAM Specified for VDD of 3 V to 5.5 V AVDD AGND AD7859–200 kSPS; AD7859L–100 kSPS System and Self-Calibration Low Power AIN1 AD7859/AD7859L I/P Normal Operation T/H MUX DV AD7859: 15 mW (VDD = 3 V) AIN8 DD AD7859L: 5.5 mW (VDD = 3 V) 2.5V Using Automatic Power-Down After Conversion (25
m
W) REFERENCE COMP AD7859: 1.3 mW (VDD = 3 V 10 kSPS) REFIN/ AD7859L: 650
m
W (VDD = 3 V 10 kSPS) REF BUF OUT DGND Flexible Parallel Interface: 16-Bit Parallel/8-Bit Parallel CHARGE 44-Pin PQFP and PLCC Packages C REDISTRIBUTION REF1 DAC APPLICATIONS CLKIN Battery-Powered Systems (Personal Digital Assistants, CREF2 SAR + ADC CONVST Medical Instruments, Mobile Communications) CALIBRATION MEMORY CONTROL BUSY AND Pen Computers CONTROLLER SLEEP Instrumentation and Control Systems CAL High Speed Modems PARALLEL INTERFACE/CONTROL REGISTER GENERAL DESCRIPTION
The AD7859/AD7859L are high speed, low power, 8-channel,
DB15 – DB0 RD CS WR W/B
12-bit ADCs which operate from a single 3 V or 5 V power supply, the AD7859 being optimized for speed and the AD7859L for low power. The ADC contains self-calibration
PRODUCT HIGHLIGHTS
and system calibration options to ensure accurate operation over 1. Operation with either 3 V or 5 V power supplies. time and temperature and have a number of power-down 2. Flexible power management options including automatic options for low power applications. power-down after conversion. The AD7859 is capable of 200 kHz throughput rate while the 3. By using the power management options a superior power AD7859L is capable of 100 kHz throughput rate. The input performance at slower throughput rates can be achieved. track-and-hold acquires a signal in 500 ns and features a pseudo- AD7859: 1 mW typ @ 10 kSPS differential sampling scheme. The AD7859 and AD7859L input AD7859L: 1 mW typ @ 20 kSPS voltage range is 0 to VREF (unipolar) and –VREF/2 to +VREF/2 4. Operates with reference voltages from 1.2 V to the supply. about VREF/2 (bipolar) with both straight binary and 2s comple- ment output coding respectively. Input signal range is to the 5. Analog input ranges from 0 V to VDD. supply and the part is capable of converting full-power signals to 6. Self and system calibration. 100 kHz. 7. Versatile parallel I/O port. CMOS construction ensures low power dissipation of typically 8. Lower power version AD7859L. 5.4 mW for normal operation and 3.6 µW in power-down mode. The part is available in 44-pin, plastic quad flatpack package (PQFP) and plastic lead chip carrier (PLCC).
See page 28 for data sheet index.
REV. A Information furnished by Analog Devices is believed to be accurate and © Analog Devices, Inc., 1996 reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or
Tel: 617/329-4700 Fax: 617/326-8703
