Datasheet AD7716 (Analog Devices) - 7
DescriptionCMOS, 4-Channel, 22-Bit Data Acquisition System
Pages / Page17 / 7 — AD7716. ABSOLUTE MAXIMUM RATINGS1. CAUTION. WARNING!. ESD SENSITIVE …
File Format / SizePDF / 473 Kb
AD7716. ABSOLUTE MAXIMUM RATINGS1. CAUTION. WARNING!. ESD SENSITIVE DEVICE. PQFP PINOUT. PLCC PINOUT. OUT. CLKIN. CLKOUT. TFS. DGND. DRDY. SDATA
AD7716 ABSOLUTE MAXIMUM RATINGS1 CAUTION WARNING! ESD SENSITIVE DEVICE PQFP PINOUT PLCC PINOUT OUT CLKIN CLKOUT TFS DGND DRDY SDATA
PQFP Package, Power Dissipation . 450 mW (T θ A = +25°C unless otherwise noted) JA Thermal Impedance . 95°C/W AVDD to AGND . –0.3 V to +7 V Lead Temperature, Soldering AVSS to AGND . +0.3 V to –7 V Vapor Phase (60 sec) . +215°C AGND to DGND . –0.3 V to +0.3 V Infrared (15 sec) . +220°C AVDD to DVDD . –0.3 V to +0.3 V PLCC Package, Power Dissipation . 500 mW Analog Inputs to AGND . AV θ SS – 0.3 V to AVDD + 0.3 V JA Thermal Impedance . 55°C/W VREF to AGND . AVSS – 0.3 V to AVDD + 0.3 V Lead Temperature, Soldering Digital Inputs to DGND2 . –0.3 V to DVDD + 0.3 V Vapor Phase (60 sec) . +215°C Digital Outputs to DGND . –0.3 V to DVDD + 0.3 V Infrared (15 sec) . +220°C Operating Temperature Range NOTES 1 Commercial Plastic (B Versions) . –40°C to +85°C Stresses above those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional Storage Temperature Range . –65°C to +150°C operation of the device at these or any other conditions above those listed in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2Transient currents of up to 100 mA will not cause SCR latch-up.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily
WARNING!
accumulate on the human body and test equipment and can discharge without detection. Although these devices feature proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD
precautions are recommended to avoid performance degradation or loss of functionality.
PQFP PINOUT PLCC PINOUT 2 2 OUT OUT NC CLKIN NC CLKOUT D TFS DGND NC DRDY SDATA NC 44 NC 43 CLKIN 42 NC 41 CLKOUT 40 D 39 TFS 38 DGND 37 NC 36 DRDY 35 SDATA 34 NC 6 5 4 3 2 1 44 43 42 41 40 NC 7 39 MODE NC 8 38 NC NC 1 33 MODE NC 2 32 NC DOUT1 9 37 NC DOUT1 3 31 NC DGND 10 36 DVDD DGND 4 30 DVDD NC 11 35 DIN1 AD7716 NC 5 29 DIN1 AD7716 RFS 12 TOP VIEW 34 NC RFS 6 TOP VIEW 28 NC (Not to Scale) SCLK 13 33 CASCIN SCLK 7 (Not to Scale) 27 CASCIN RESET 14 32 CASCOUT RESET 8 26 CASCOUT 25 V AGND 15 31 VREF AGND 9 REF AV 24 AV DD 10 SS AVDD 16 30 AVSS AIN1 11 23 AGND AIN1 17 29 AGND 18 19 20 21 22 23 24 25 26 27 28 2 3 4 A2 IN IN A1 IN A0 A A A AGND AGND AGND AGND AGND 2 15 3 17 4 21 A2 13 IN IN A1 19 IN A0 22 NC = NO CONNECT A A A AGND 14 AGND 16 AGND 18 AGND 20 AGND 12 NC = NO CONNECT ORDERING GUIDE Temperature Output Noise Package Model Range (Filter: 146 Hz) Option*
AD7716BP –40°C to +85°C 11 µV rms P-44A AD7716BS –40°C to +85°C 11 µV rms S-44 *P = PLCC (Plastic Leaded Chip Carrier); S = PQFP (Plastic Quad Flatpack). –6– REV. A
