Datasheet AD7703 (Analog Devices) - 2
Description20-Bit A/D Converter
Pages / Page17 / 2 — AD7703* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
File Format / SizePDF / 458 Kb
AD7703* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. DOCUMENTATION
AD7703* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES DOCUMENTATION
View a parametric search of comparable parts. • AD7703 Material Declaration • PCN-PDN Information
DOCUMENTATION
• Quality And Reliability
Application Notes
• Symbols and Footprints • AN-349: Keys to Longer Life for CMOS • AN-368: Evaluation Board for the AD7701/AD7703 Sigma-
DISCUSSIONS
Delta ADCs View all AD7703 EngineerZone Discussions. • AN-375: ADM2xxL Family for RS-232 Communications • AN-607: Selecting a Low Bandwidth (<15 kSPS) Sigma-
SAMPLE AND BUY
Delta ADC Visit the product page to see pricing options.
Data Sheet
• AD7703: LC2MOS 20-Bit Sigma-Delta ADC Data Sheet
TECHNICAL SUPPORT
Submit a technical question or find your regional support
TOOLS AND SIMULATIONS
number. • Sigma-Delta ADC Tutorial
DOCUMENT FEEDBACK REFERENCE MATERIALS
Submit feedback for this data sheet.
Technical Articles
• Delta-Sigma Rocks RF, As ADC Designers Jump On Jitter • MS-2210: Designing Power Supplies for High Speed ADC
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE TIMING CHARACTERISTICS DEFINITION OF TERMS Linearity Error Differential Linearity Error Positive Full-Scale Error Unipolar Offset Error Bipolar Zero Error Bipolar Negative Full-Scale Error Positive Full-Scale Overrange Negative Full-Scale Overrange Offset Calibration Range Full-Scale Calibration Range Input Span PIN CONFIGURATION DIP, CERDIP, SOIC PIN FUNCTION DESCRIPTIONS GENERAL DESCRIPTION THEORY OF OPERATION DIGITAL FILTERING FILTER CHARACTERISTICS USING THE AD7703 SYSTEM DESIGN CONSIDERATIONS CLOCKING ANALOG INPUT RANGES ACCURACY AUTOCALIBRATION Initiating Calibration Span and Offset Limits POWER-UP AND CALIBRATION Drift Considerations INPUT SIGNAL CONDITIONING Source Resistance Antialias Considerations VOLTAGE REFERENCE CONNECTIONS POWER SUPPLIES AND GROUNDING SLEEP MODE DIGITAL INTERFACE Synchronous Self-Clocking Mode (SSC) Synchronous External Clock Mode (SEC) DIGITAL NOISE AND OUTPUT LOADING OUTLINE DIMENSIONS REVISION HISTORY
