Datasheet AD1674 (Analog Devices) - 5
Description12-Bit, 100 kSPS, Complete ADC
Pages / Page13 / 5 — AD1674–SPECIFICATIONS. AC SPECIFICATIONS MIN to TMAX, with VCC = +15 V. …
RevisionC
File Format / SizePDF / 291 Kb
AD1674–SPECIFICATIONS. AC SPECIFICATIONS MIN to TMAX, with VCC = +15 V. 10% or +12 V. 5%, VLOGIC = +5 V. 10%, VEE = –15 V. 10% or
AD1674–SPECIFICATIONS AC SPECIFICATIONS MIN to TMAX, with VCC = +15 V 10% or +12 V 5%, VLOGIC = +5 V 10%, VEE = –15 V 10% or
AD1674–SPECIFICATIONS (T AC SPECIFICATIONS MIN to TMAX, with VCC = +15 V
6
10% or +12 V
6
5%, VLOGIC = +5 V
6
10%, VEE = –15 V
6
10% or –12 V
6
5%, fSAMPLE = 100 kSPS, fIN = 10 kHz, stand-alone mode unless otherwise noted)1 AD1674J/A AD1674K/B/T Parameter Min Typ Max Min Typ Max Units
Signal to Noise and Distortion (S/N+D) Ratio2, 3 69 70 70 71 dB Total Harmonic Distortion (THD)4 –90 –82 –90 –82 dB 0.008 0.008 % Peak Spurious or Peak Harmonic Component –92 –82 –92 –82 dB Full Power Bandwidth 1 1 MHz Full Linear Bandwidth 500 500 kHz Intermodulation Distortion (IMD)5 Second Order Products –90 –80 –90 –80 dB Third Order Products –90 –80 –90 –80 dB SHA (Specifications are Included in Overall Timing Specifications) Aperture Delay 50 50 ns Aperture Jitter 250 250 ps Acquisition Time 1 1 µs
(for all grades T DIGITAL SPECIFICATIONS MIN to TMAX, with VCC = +15 V
6
10% or +12 V
6
5%, VLOGIC = +5 V
6
10%, VEE = –15 V
6
10% or –12 V
6
5%) Parameter Test Conditions Min Max Units
LOGIC INPUTS VIH High Level Input Voltage +2.0 VLOGIC +0.5 V V VIL Low Level Input Voltage –0.5 +0.8 V IIH High Level Input Current (VIN = 5 V) VIN = VLOGIC –10 +10 µA IIL Low Level Input Current (VIN = 0 V) VIN = 0 V –10 +10 µA CIN Input Capacitance 10 pF LOGIC OUTPUTS VOH High Level Output Voltage IOH = 0.5 mA +2.4 V VOL Low Level Output Voltage IOL = 1.6 mA +0.4 V IOZ High-Z Leakage Current VIN = 0 to VLOGIC –10 +10 µA COZ High-Z Output Capacitance 10 pF NOTES 1fIN amplitude = –0.5 dB (9.44 V p-p) 10 V bipolar mode unless otherwise noted. All measurements referred to –0 dB (9.997 V p-p) input signal unless otherwise noted. 2Specified at worst case temperatures and supplies after one minute warm-up. 3See Figures 12 and 13 for other input frequencies and amplitudes. 4See Figure 11. 5fa = 9.08 kHz, fb = 9.58 kHz with fSAMPLE = 100 kHz. See Definition of Specifications section and Figure 15. All min and max specifications are guaranteed. Specifications subject to change without notice. –4– REV. C
