Data SheetADL5205TYPICAL PERFORMANCE CHARACTERISTICS Supply voltage (VPOS) = 3.3 V or 5 V, TA = 25°C, ZLOAD = 200 Ω, maximum gain (gain code = 000000), 2 V p-p composite differential output for intermodulation distortion (IMD) and OIP3, 2 V p-p differential output for second harmonic distortion (HD2) and third harmonic distortion (HD3), VCMA = VCMB = VPOS/2, unless otherwise noted. 185601843.45V1833.3V1823.15V501815.25V1805.0VA) 1794.75V(m 17840T)N 177Em176B d175303 (174CURR 173LYOIPP 17220UP 171S5V, 26dB1705V, 14dB169105V, 6dB1683.3V, 26dB1673.3V, 14dB1663.3V, 6dB1650 09 –402585 06 0100200300400500 0 0 88- TEMPERATURE (°C)FREQUENCY (MHz) 3488- 1 134 Figure 6. Supply Current vs. Temperature, PM = 0 Figure 9. Output Third-Order Intercept (OIP3) vs. Frequency over VPOS at Three Gain Codes, High Performance Mode 145603.45V1433.3V 3.15V501415.25V)5.0VA 1394.75Vm (40NT 137) m B d135303 (CURRE 133LYOIPP20UP 131S5V, +85°C 5V, +25°C129105V, –40°C 3.3V, +85°C1273.3V, +25°C 3.3V, –40°C1250 10 –402585 07 0100200300400500 0 0 8- TEMPERATURE (°C)FREQUENCY (MHz) 3488- 348 1 1 Figure 7. Supply Current vs. Temperature, PM = 1 Figure 10. Output Third-Order Intercept (OIP3) vs. Frequency over VPOS for Three Temperatures at Maximum Gain, High Performance Mode 3060–40°C+25°C25+85°C50201540)) m10B(dBd30IN3 (5GAOIP0205V, 26dB–55V, 14dB105V, 6dB 3.3V, 26dB–103.3V, 14dB 3.3V, 6dB–150 1 8 1 05101520253035400100200300400500 0 -00 8 GAIN CODE 48 FREQUENCY (MHz) 3488- 1 13 Figure 8. Gain vs. Gain Code over Temperature at 200 MHz Figure 11. Output Third-Order Intercept (OIP3) vs. Frequency over VPOS at Three Gain Codes, Low Power Mode Rev. 0 | Page 9 of 31 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE JUNCTION TO BOARD THERMAL IMPEDANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC STRUCTURE CONTROL/LOGIC CIRCUITRY COMMON-MODE VOLTAGE APPLICATIONS INFORMATION BASIC CONNECTIONS DIGITAL INTERFACE OVERVIEW Parallel Digital Interface Serial Peripheral Interface (SPI) Up/Down Interface SPI READ ADC INTERFACING NOISE FIGURE vs. GAIN SETTING EVALUATION BOARD OVERVIEW POWER SUPPLY INTERFACE SIGNAL INPUTS AND OUTPUTS MANUAL CONTROLS Mode Switches Channel Control Switches PARALLEL INTERFACE SERIAL INTERFACE STANDARD DEVELOPMENT PLATFORM (SDP) INTERFACE EVALUATION BOARD CONTROL SOFTWARE COMMAND LINE CONTROL PROGRAM GRAPHICAL USER INTERFACE (GUI) PROGRAM EVALUATION BOARD SCHEMATICS AND LAYOUT BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
