Datasheet ADL5565 (Analog Devices) - 5
Description | 6 GHz Ultrahigh Dynamic Range Differential Amplifier |
Pages / Page | 29 / 5 — ADL5565. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max … |
Revision | G |
File Format / Size | PDF / 909 Kb |
ADL5565. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max Unit
ADL5565 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
NOISE/HARMONIC PERFORMANCE 10 MHz Second/Third Harmonic Distortion (HD2/HD3) AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −107/−110 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −101/−107 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −106/−112 dBc Output IP3/Third-Order Intermodulation AV = 6 dB, RL = 200 Ω, VOUT = +48/−100 dBm/dBc Distortion (OIP3/IMD3) 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = +52/−108 dBm/dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = +50/−104 dBm/dBc 2 V p-p composite (2 MHz spacing) Second-Order Intermodulation Distortion (IMD2) AV = 6 dB, RL = 200 Ω, VOUT = −86 dBc 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = −86 dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = −86 dBc 2 V p-p composite (2 MHz spacing) Noise Spectral Density, RTI (NSD) AV = 6 dB 2.24 nV/√Hz AV = 12 dB 1.52 nV/√Hz AV = 15.5 dB 1.53 nV/√Hz Noise Figure (NF) AV = 6 dB 10.24 dB AV = 12 dB 8.66 dB AV = 15.5 dB 8.78 dB 1 dB Compression Point, RTO (OP1dB) AV = 6 dB 13.1 dBm AV = 12 dB 12.8 dBm AV = 15.5 dB 13.1 dBm 100 MHz Second/Third Harmonic Distortion (HD2/HD3) AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −108/−103 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −91/−99 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −89/−100 dBc Output IP3/Third-Order Intermodulation AV = 6 dB, RL = 200 Ω, VOUT = +54/−112 dBm/dBc Distortion (OIP3/IMD3) 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = +53/−110 dBm/dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = +52/−108 dBm/dBc 2 V p-p composite (2 MHz spacing) Second-Order Intermodulation Distortion (IMD2) AV = 6 dB, RL = 200 Ω, VOUT = −85 dBc 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = −85 dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = −86 dBc 2 V p-p composite (2 MHz spacing) Noise Spectral Density, RTI (NSD) AV = 6 dB 2.25 nV/√Hz AV = 12 dB 1.53 nV/√Hz AV = 15.5 dB 1.52 nV/√Hz Noise Figure (NF) AV = 6 dB 10.27 dB AV = 12 dB 8.69 dB AV = 15.5 dB 8.7 dB 1 dB Compression Point, RTO (OP1dB) AV = 6 dB 13 dBm AV = 12 dB 12.8 dBm AV = 15.5 dB 12.8 dBm Rev. E | Page 4 of 28 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications 3.3 V Specifications 5 V Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description Basic Structure Applications information Basic Connections Input and Output Interfacing Single-Ended Input to Differential Output Gain Adjustment and Interfacing ADC Interfacing Layout Considerations Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
